03-11-2013 11:05 AM - edited 03-16-2019 04:11 PM
Hi Everyone,
I've been struggling with this for a while now, gave up on the h323 connectivity and went back to SIP. Here is the scenario: We have a Cisco Unified Communication Manager 6.1 system in one office, which is up and running and working fine. This system uses 4-digit dialing for internal extensions, all starting with 7XXX. We also have a CME running at a remote location, all extensions 8XXX. All is working fine there as well. We have an MPLS network between the two, and IP connectivity is solid and easily visible.
Now, What I'm trying to do is allow users at the main site to call the remote site using 228xxx, which is working. This is across SIP trunk to remote site. The remote site should be able to dial 217xxx and get the 4-digit extension at HQ. I see the SIP invites go out, yet the calls never go through. I'm struggling to find a cause in the CUCM that is denying the call...
The CME Relevant configurations:
Current configuration : 49762 bytes
voice service voip
ip address trusted list
ipv4 10.96.178.0 255.255.255.0
ipv4 <CUCM-Primary>
ipv4 <CUCM-Secondary>
allow-connections h323 to sip
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
h245 signal update
sip
registrar server expires max 3600 min 3600
voice translation-rule 10
rule 10 /^21/ //
voice translation-rule 11
rule 11 /^22/ //
voice translation-profile CUCM-INBOUND
translate called 11
voice translation-profile CUCM-OUTBOUND
translate calling 10
translate called 10
dial-peer voice 210 voip
description *** OUTBOUND to CUCM CALL MANAGER TEST ***
translation-profile outgoing CUCM-OUTBOUND
destination-pattern 21....
session protocol sipv2
session target ipv4:<CUCM-Subscriber>
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
dial-peer voice 211 voip
description *** INCOMING CALLS FROM CUCM ****
group-name FairlawnIncoming
destination-pattern 8...
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
no remote-party-id
retry invite 2
retry register 10
timers connect 100
host-registrar
telephony-service
no auto-reg-ephone
authentication credential cmeadmin d3l3m@
max-ephones 95
max-dn 95
ip source-address <CME IP Address> port 2000
timeouts interdigit 3
timeouts ringing 20
system message VEYANCE
time-zone 43
voicemail 7999
max-conferences 8 gain -6
call-forward pattern 4....
moh "flash:music-on-hold.au"
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Aug 20 2012 21:17:28
Call Manager has a SIP Trunk setup with a separate device pool, Call Classification "On Net"
Again, outbound calls to the CME work fine. Inbound from CME to CUCM do not work at all... here is a test, dialing 217163 on the CME:
I am running this with the following debugs enabled:
DIALPEER:
debug voip dialpeer detail is ON (filter is OFF)
CCAPI:
debug voip ccapi inout is ON (filter is OFF)
CCSIP SPI: SIP Call Statistics tracing is enabled (filter is OFF)
CCSIP SPI: SIP Call Events tracing is enabled (filter is OFF)
Here is the debug output from call from 8500 to 217163:
Mar 11 17:35:43.334: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=8500
Mar 11 17:35:43.334: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Is Incoming=TRUE, Number Expansion=FALSE
Mar 11 17:35:43.334: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=8500T
Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
Result=-1
Match Rule=DP_MATCH_ORIGINATE; Calling Number=8500
Mar 11 17:35:43.334: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=211 Is Matched
Result=Success(0); Incoming Dial-peer=20096 Is Matched
Mar 11 17:35:43.334: //-1/EF178EEE90B5/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=8500
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Mar 11 17:35:43.334: //-1/EF178EEE90B5/CCAPI/cc_api_call_setup_ind_common:
Interface=0x1CA10704, Call Info(
Calling Number=8500,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=20096, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Mar 11 17:35:43.334: //-1/EF178EEE90B5/CCAPI/ccCheckClipClir:
In: Calling Number=8500(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=8500(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Mar 11 17:35:43.334: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 11 17:35:43.334: :cc_get_feature_vsa malloc success
Mar 11 17:35:43.334: cc_get_feature_vsa count is 1
Mar 11 17:35:43.334: :FEATURE_VSA attributes are: feature_name:0,feature_time:504015312,feature_id:147573
Mar 11 17:35:43.334: //775709/EF178EEE90B5/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=8500(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
Mar 11 17:35:43.334: //775709/EF178EEE90B5/CCAPI/cc_process_call_setup_ind:
Event=0x1620BED0
Mar 11 17:35:43.334: //775709/EF178EEE90B5/CCAPI/ccCallSetContext:
Context=0x117C92D4
>>>>CCAPI handed cid 775709 with tag 20096 to app "_ManagedAppProcess_Default"
Mar 11 17:35:43.334: //775709/EF178EEE90B5/CCAPI/ccCallSetupAck:
Call Id=775709
Mar 11 17:35:43.334: //775709/EF178EEE90B5/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
Mar 11 17:35:43.334: //775709/EF178EEE90B5/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=775709
Mar 11 17:35:43.338: //775709/EF178EEE90B5/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Mar 11 17:35:43.338: //775709/EF178EEE90B5/CCAPI/ccCallReportDigits:
(callID=0xBD61D, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Call Id=775709
Mar 11 17:35:43.338: //775709/EF178EEE90B5/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x1CA10704, callID=0xBD61D, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Disposition=0x0, Interface=0x1CA10704, Call Id=775709
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=3000(ms))
Mar 11 17:35:43.538: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_begin:
Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Source Call Id=775709, Digit=2, DigitBeginFlags=0x0,
Rtp Timestamp=0x21493D8, Rtp Expiration=0x0
Mar 11 17:35:43.538: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_end:
Source Call Id=775709, Digit=2, Duration=100,
Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Call Entry(Handoff Depth=0)
Mar 11 17:35:43.538: //-1/EF178EEE90B5/DPM/dpMatchCore:
Veyance_CME#Dial String=2, Expanded String=2, Calling Number=
Timeout=FALSE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Mar 11 17:35:43.538: //-1/EF178EEE90B5/DPM/MatchNextPeer:
Result=MORE_DIGITS_NEEDED(1); Outgoing Dial-peer=210
Result=1
Mar 11 17:35:43.738: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_begin:
Source Call Id=775709, Digit=1, DigitBeginFlags=0x0,
Rtp Timestamp=0x21510D8, Rtp Expiration=0x0
Mar 11 17:35:43.738: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_end:
Source Call Id=775709, Digit=1, Duration=100,
Mar 11 17:35:43.738: //-1/EF178EEE90B5/DPM/dpMatchCore:
Dial String=21, Expanded String=21, Calling Number=
Mar 11 17:35:43.738: //-1/EF178EEE90B5/DPM/MatchNextPeer:
Result=1
Mar 11 17:35:43.938: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_begin:
Source Call Id=775709, Digit=7, DigitBeginFlags=0x0,
Rtp Timestamp=0x2158DD8, Rtp Expiration=0x0
Mar 11 17:35:43.938: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_end:
Source Call Id=775709, Digit=7, Duration=100,
Mar 11 17:35:43.938: //-1/EF178EEE90B5/DPM/dpMatchCore:
Dial String=217, Expanded String=217, Calling Number=
Mar 11 17:35:43.938: //-1/EF178EEE90B5/DPM/MatchNextPeer:
Result=1
Mar 11 17:35:44.138: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x2160AD8, Rtp Expiration=0x0
Mar 11 17:35:44.138: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_end:
Mar 11 17:35:44.138: //-1/EF178EEE90B5/DPM/dpMatchCore:
Dial String=2171, Expanded String=2171, Calling Number=
Mar 11 17:35:44.138: //-1/EF178EEE90B5/DPM/MatchNextPeer:
Result=1
Mar 11 17:35:44.338: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_begin:
Source Call Id=775709, Digit=6, DigitBeginFlags=0x0,
Rtp Timestamp=0x21687D8, Rtp Expiration=0x0
Mar 11 17:35:44.338: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_end:
Source Call Id=775709, Digit=6, Duration=100,
Mar 11 17:35:44.338: //-1/EF178EEE90B5/DPM/dpMatchCore:
Dial String=21716, Expanded String=21716, Calling Number=
Mar 11 17:35:44.338: //-1/EF178EEE90B5/DPM/MatchNextPeer:
Result=1
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_begin:
Source Call Id=775709, Digit=3, DigitBeginFlags=0x0,
Rtp Timestamp=0x21704D8, Rtp Expiration=0x0
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/cc_api_call_digit_end:
Source Call Id=775709, Digit=3, Duration=100,
Mar 11 17:35:44.538: //-1/EF178EEE90B5/DPM/dpMatchCore:
Dial String=217163, Expanded String=217163, Calling Number=
Mar 11 17:35:44.538: //-1/EF178EEE90B5/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=210 Is Matched
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/ccCallReportDigits:
(callID=0xBD61D, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x1CA10704, callID=0xBD61D, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
Mar 11 17:35:44.538: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Mar 11 17:35:44.538: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Mar 11 17:35:44.538: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
Mar 11 17:35:44.538: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Dial String=217163, Expanded String=217163, Calling Number=217163T
Match Rule=DP_MATCH_ANSWER; Calling Number=217163
Dial String=, Expanded String=, Calling Number=217163T
Result=-1
Match Rule=DP_MATCH_ORIGINATE; Calling Number=217163
Result=Success(0); Incoming Dial-peer=210 Is Matched
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=210, Params=0x3AFB7F8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Mar 11 17:35:44.538: //775709/EF178EEE90B5/CCAPI/ccCheckClipClir:
Destination Pattern=21...., Called Number=7163, Digit Strip=FALSE
Called Number=7163(TON=Unknow
Veyance_CME#n, NPI=Unknown),
Redirect Number=, Display Info=Testing
Account Number=, Final Destination Flag=FALSE,
Guid=EF178EEE-89A8-11E2-90B5-9DDB61BF2B12, Outgoing Dial-peer=210
Mar 11 17:35:44.542: //775709/EF178EEE90B5/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=8500
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=7163
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
Mar 11 17:35:44.542: //775709/EF178EEE90B5/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x24701AC, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=8500,(Calling Name=Testing)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=7163(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=210, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Mar 11 17:35:44.542: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 11 17:35:44.542: :cc_get_feature_vsa malloc success
Mar 11 17:35:44.542: cc_get_feature_vsa count is 2
Mar 11 17:35:44.542: :FEATURE_VSA attributes are: feature_name:0,feature_time:504012176,feature_id:147574
Mar 11 17:35:44.542: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Mar 11 17:35:44.542: //775710/EF178EEE90B5/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Mar 11 17:35:44.542: //775710/EF178EEE90B5/CCAPI/ccCallSetContext:
Context=0x3AFB7A8
Mar 11 17:35:44.542: //775709/EF178EEE90B5/CCAPI/ccSaveDialpeerTag:
Mar 11 17:35:44.542: //775710/EF178EEE90B5/CCAPI/cc_api_call_proceeding:
Interface=0x24701AC, Progress Indication=NULL(0)
Mar 11 17:35:44.542: //775710/EF178EEE90B5/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Mar 11 17:35:44.542: //775710/EF178EEE90B5/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:154D2CFC
Mar 11 17:35:44.878: //775710/EF178EEE90B5/CCAPI/cc_api_call_disconnected:
Cause Value=63, Interface=0x24701AC, Call Id=775710
Call Entry(Responsed=TRUE, Cause Value=63, Retry Count=0)
Mar 11 17:35:44.878: //775709/EF178EEE90B5/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
Mar 11 17:35:44.878: //775710/EF178EEE90B5/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=775710
Mar 11 17:35:44.878: //775710/EF178EEE90B5/CCAPI/ccCallDisconnect:
Cause Value=63, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=63)
Cause Value=63, Call Entry(Responsed=TRUE, Cause Value=63)
Mar 11 17:35:44.878: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Mar 11 17:35:44.878: //775710/EF178EEE90B5/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Mar 11 17:35:44.878: //775710/EF178EEE90B5/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x24701AC, Tag=0x0, Call Id=775710,
Call Entry(Disconnect Cause=63, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Mar 11 17:35:44.878: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 11 17:35:44.878: :cc_free_feature_vsa freeing 1E0A9D88
Mar 11 17:35:44.878: vsacount in free is 1
Mar 11 17:35:44.878: //775710/EF178EEE90B5/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x166A6DC8
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 8500
Called Number : 7163
Source IP Address (Sig ): 10.96.178.2
Destn SIP Req Addr:Port : 10.96.210.2:5060
Destn SIP Resp Addr:Port : 10.96.210.2:5060
Destination Name : 10.96.210.2
Mar 11 17:35:44.878: //775710/EF178EEE90B5/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 10.96.178.2
Source IP Port (Media): 29942
Destn IP Address (Media): -
Destn IP Port (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC) : 63
Disconnect Cause (SIP) : 503
Veyance_CME#
Mar 11 17:35:44.878: //775709/EF178EEE90B5/CCAPI/ccCallDisconnect:
Cause Value=63, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Mar 11 17:35:44.878: //775709/EF178EEE90B5/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
Veyance_CME#
Mar 11 17:35:46.306: //775709/EF178EEE90B5/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x1CA10704, Tag=0x0, Call Id=775709,
Mar 11 17:35:46.306: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 11 17:35:46.306: :cc_free_feature_vsa freeing 1E0AA9C8
Mar 11 17:35:46.306: vsacount in free is 0
In previous debugs, I did come across a SIP/2.0 503 error as well, but not at this time...
Any help/suggestions are appreciated.
Solved! Go to Solution.
03-13-2013 05:40 AM
Made no difference.
03-12-2013 09:43 AM
Ok, the phone is registered through the CME as a Cisco Ip Communicator phone, but when it attempts to call the CUCm, it appears to act as if it comes from the sip provider. Why is that?
03-12-2013 12:33 PM
It looks like you are using the same interface for both the Skype and CUCM sip calls? If this is the case then bindings are not going to be a problem. As a test you could use a sip profile on your outbound dialpeer to CUCM to replace the sip provider information in the from header with the IP address of the cme router. Something like
voice class sip-profiles 100
request INVITE sip-header From modify "
dial-peer voice xxx voip
voice-class sip-profiles 100
Use this website for more info on sip profiles
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a0080982499.shtml#steps
Back on the calling search space suggestion, the sip trunk uses the calling search space assigned to determine where inbound calls to the sip trunk are allowed to be routed. Therefore if the 7xxx extension reside in a partition on CUCM the sip trunk will need a calling search space that has that same partition included in it.
03-13-2013 05:39 AM
In regards to the calling search space, one was previously created and is still in use. I haven't stopped using it, so I don't know that it is the problem, unless I'm not understanding what you mean.
I'm a little fuzzy on what you are asking for regarding the SIP profiles, are you talking about on the CME or on the UCM?
03-13-2013 05:45 AM
Ok..Ken.This is serious..But lets keep going...
Can you send me CUCM traces? Ensure you enable detailed traces in CUCM and send the trace for a failed test call..In the mean time..Please send the ff traces
debug ccsip all
Do another test call and please attach the trace as zip file here..It can be a lot of logs so dont paste just attach.
Once you are done..gather cucm traces and send to me ( i will need to see the ips so I can troubleshoot..If you want to send me a PM and attach the trace then thats fine..
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
03-13-2013 12:45 PM
I sent you a private message, please provide me your email address in it, so I can work with you on the problem. I will review the traces to insure nothing insecure is in there, then post them here if possible, but would prefer to email them to you directly.
03-13-2013 12:53 PM
Ken,
I have replied. Let me know once you have sent the traces
03-13-2013 01:01 PM
On the way now.
03-13-2013 03:27 PM
Ken,
I have looked at the logs and found the correct traces...Questions for you
1. Does the ip address on the sip trunk match the ip address of the CME gateway where you have the bind command
2. Does the CCM group on th sip trunk has the CUCM subscriber in it?
03-14-2013 04:42 AM
Can you change the dial-peer pointing to CCM to h323 instead of SIP ? when you change you need to add the CME as an H323 Gateway.
voice class h323 2
h225 timeout tcp establish 3
h225 timeout setup 3
description *** INCOMING CALLS FROM FAIRLAWN ****
session target ipv4:<---IP Address of CUCM Subscriber Server--->
voice-class codec 1
voice-class h323 2
dtmf-relay h245-alphanumeric
interface GigabitEthernet0/2
description CONNECTION TO CME-LAN "$ES_LAN$"
ip address <--- IP Address of CME ---> 255.255.255.0
h323 voip interface
h323 voip bind srcipp <--- IP Address of CME --->
it seems when you use sip, it looks for a SIP endpoint instead of skinny endpoint
Anas
please rate if it is helpful
03-14-2013 04:59 AM
Annas,
Why should he do that? Because he has issues with SIP means he should go back to H323...NO thats not right..
03-14-2013 05:03 AM
do you think H323 is bad ?? if it works at least he has a plan B to figure out this issue.
regards
Anas
03-14-2013 05:11 AM
Been there done that. Actually came to SIP when H323 had same issue.
So whether running on H323 or SIP, calls only flow one way.
03-14-2013 05:15 AM
Ken,
did you see my post yesterday.. Can you check the device pool on the sip trunk.. Ensure the CUCM group assigned to it has the subscriber in it
03-14-2013 05:25 AM
I did not, but I will look.
Ok, I'm not sure how to put the subscriber in a 'device pool'... maybe I'm missing your point.
The device pool is called Manila_Device_Pool
The SIP trunk has is flagged with Manila_Device_Pool
So how would I put the subscriber into the pool? I guess I don't understand what you're asking. Let me look at the original message you sent about it...
1. Does the ip address on the sip trunk match the ip address of the CME gateway where you have the bind command?
Yes
Where do you intend for me to put the subscriber into a group... I'm not following your logic on this one.
Thanks, Ken
