ā01-09-2013 06:27 AM - edited ā03-16-2019 03:04 PM
Hi all
We are using SNR (single number reach), but when I'm busy with my IP Phone, and a second call comes in, it will extend to my mobile phone.
I have the following configuration for my Line: (I have two Devices, one Hard- and one Softphone)
or | |||
or | |||
or | |||
or |
If I'm busy with my Hard- or Sofphone, the SNR should not forward the call to my mobile phone.
We have a CUCM 8.6.2 System...
How can I configure this?
Thanks for your help.
Pascal
ā01-09-2013 06:38 AM
So what you're saying is that your line doesn't have your mobile phone number under the Call Forward Busy? If so, are you using Remote Destinatin Profiles?
Yosh
ā01-09-2013 06:40 AM
If you're not using Remote Destination Profiles did you have Unity (or a third party voice mail system) send the calls to your mobile device?
Yosh
ā01-09-2013 10:56 PM
Right, I don't have my mobile number in the "Call Forwar Busy" field.
We use RDP with Remote Destination and the RD is my mobile phone.
We have Unity but its just for VM and not to forward calls.
Rgerads,
Pascal
ā01-10-2013 06:09 AM
Pascal,
The reason why your mobile phone is ringing is because of RDP. If you don't want to use RDP when you are in the office than you can turn off your mobile connect using the mobile connect softkey.
Yosh
ā04-27-2015 10:14 PM
Hi Pascal.
Did you ever get this resolved? I have the same problem on my 10.6 system. RDP DN busy trigger is 1, but a second call gets bridged to the mobile?
