03-25-2011 08:05 PM - edited 03-16-2019 04:10 AM
Hi Guys,
My Customer is changing the CallManager verson 4.1 to 7.1. I used the DMA and I have the following doubt: My Customer using the Service Attendant Console, I need to download of pluging about Attendant Console the CallManager 7.1 or it worked with the software previous (Version 4.1)
Thank You,
Wilson
Solved! Go to Solution.
03-25-2011 08:25 PM
You always need to install the AC from the version you're running.
If you're running 4.X, then download and integrate it to that version.
If you're on 7.X, then download and integrate to that version.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
03-25-2011 08:30 PM
Yes, any plugins you had on 4.X and want to use after the 7.X migration need to be updated.
java
03-25-2011 08:25 PM
java
03-25-2011 08:28 PM
Hi Javalenc,
Thank You for your help. I have another question, I need change de JTapi too?
Wilson
03-25-2011 08:30 PM
java
