Software Attendant Console
wilsonsant
Level 6
Level 6
Hi Guys,
My Customer is changing the CallManager verson 4.1 to 7.1. I used the DMA and I have the following doubt: My Customer using the Service Attendant Console, I need to download of pluging about Attendant Console the CallManager 7.1 or it worked with the software previous (Version 4.1)
Thank You,
Wilson
2 Accepted Solutions
Jaime Valencia
You always need to install the AC from the version you're running.
If you're running 4.X, then download and integrate it to that version.
If you're on 7.X, then download and integrate to that version.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Yes, any plugins you had on 4.X and want to use after the 7.X migration need to be updated.
java
java
Jaime Valencia
java
java
Hi Javalenc,
Thank You for your help. I have another question, I need change de JTapi too?
Wilson
java
java
