SPAN Voice Recording Issue
mobyzoneuk
Hi guys, I don't know much about SPAN so please advise me if i've posted in the wrong section.
Basically we have a voice recorder that records our VOIP traffic but we think the SPAN has been set up wrong. I'll try explain how it works.
VOIP Handsets - VLAN 30
VOIP Call Servers - VLAN 31
We have a voice recording server with 2 SPAN ports for redundancy, one is plugged into a 6500 Catalyst switch which works fine and monitors traffic on vlan 30 and forwards it to the voice recorder but then we have the other plugged into a 3560 switch and this is only recording 1 side of the conversation.
We have 2 Avaya Call Server LSP's, 1 in 1 building and 1 in our main building. When calls come through to the LSP in our building it records both sides of the conversation and we think this is because the routing is taking place through the 6500 catalyst switch. When they come into the LSP in the other building and ultimately through span port 2 which is connected to the 3560 it only records 1 side. The config we have for SPAN port 2 is the following:
interface GigabitEthernet0/1
description 2nd SPAN Port for eutee-vrec1p
switchport access vlan 31
switchport mode access
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2 priority-queue out
mls qos trust cos
auto qos voip trust
spanning-tree portfast
service-policy input VOIP
The monitor session config for this switch is as following:
monitor session 1 source vlan 30
monitor session 1 destination interface Gi0/1
When I do a show monitor session 1 we get the following:
Session 1
Type                   : Local Session
Source VLANs           :
    Both               : 30
Destination Ports      : Gi0/17
    Encapsulation      : Native
          Ingress      : Disabled
We tried turning the ingress on but still the same. The minute we turn the span on aswell and run wireshark all traffic stops on the port. If i havent made any sense please do let me know.
Many Thanks
Rejohn Cuares
Level 4
Level 4
Refer to this link on how to setup RSPAN.
https://supportforums.cisco.com/docs/DOC-32763
Please rate replies and mark question as "answered" if applicable.
9 Replies 9
afmmanicke
Could you lay out you topology a bit better?   Maybe I'm getting confused here, but it sounds like you trying to record phones tha are not directly attached to the same switch as that the server is connected to.   In that case wouldn't you want to use an RSPAN?
Also wouldn't you want to your voice VLAN on the interface that your server is connected to?   (Again I'm confused here) It looks like Gi 0/1 is your server's switch port, but the show monitor session 1 is saying that the destination port is Gi0/17.
Here's a snippit from my environment:
interface FastEthernet0/44
description Call Monitor
switchport access vlan 5
switchport voice vlan 67
speed 100
duplex half
monitor session 1 source vlan 67
monitor session 1 destination interface Fa0/44 ingress untagged vlan 67
switch1#show mon session 1
Session 1
Source VLANs           :
    Both               : 67
Destination Ports      : Fa0/44
          Ingress      : Enabled, default VLAN = 67
    Ingress encap : Untagged
Hope that helps.
TONY
Hi there,
Yep we are wanting to span to a different switch. Sorry I don't think I was clear enough originally so i'll try again :-)
VOIP Handsets are in VLAN 30
VOIP Servers are in VLAN 31
We have a VOIP server plugged into 1 switch in our Fire Station and that is in VLAN 31 and have the following monitor set up:
monitor session 1 source interface Gi0/42
monitor session 1 destination remote vlan 30
Do we need to SPAN the handsets VLAN or the Servers VLAN?
We also have a VOIP server plugged into 1 switch in our HQ Building and also in VLAN 31 but also have a cable from our voice recording server to this same switch.
Port Gi0/1 is our voice recording server
Session 1
Source VLANs           :
    Both               : 30
          Ingress      : Disabled
So basically we would like to retrieve the voice traffic and record it from the Fire Station building using the RSPAN to the VLAN and then pick it up using the source command in the HQ building.
Rejohn Cuares
Level 4
Level 4
Will have a look at this now thanks
The above link looks like it has good details to get this done.
To answer your question, "Do we need to SPAN the handsets VLAN or the Servers VLAN?"   Your voice traffic will will be end to end communication - phone to phone or PSTN connection to phone.   The server is there mostly for call setup.   Therefore you will need to span your handset VLANs.
Hi there, yep followed that guide however we cannot set the monitor session 1 source remote vlan 90 (our RSPAN VLAN) as the fibre goes directly into a Catalyst 6506 so we tried setting up this:
Set vlan 90 rspan
Set rspan source 30 90 both
Set rspan destination 4/10 90
We have no switches with VTP Mode Server our VTP Server is on the Catalyst 6506 Core Switch if that helps.
However still one sided recordings, so frustrating :-(
I'm not sure who your call recording solution is through, but here's one company's take on setup and configuration: http://www.vpi-corp.com/resources/manuals/VPI_ActivIP_Setup_%28Rev1%29.pdf
Page 5 outlines some basics and page 12 details the configuration.   A few things to note.   Your VTP configuration should propigate the RSPAN VLAN info.   Is your switch in a seperate VTP domain?   Maybe verify that the VLAN is being propigated by doing a show vlan.
Our VTP Domain is all setup correctly and the VLAN's were being propagated  across our switches. We looked through the guide again and seem to of sorted it.
Thanks anyway for your help.
Javier Acuña
Hola buenos días, para solventar este problema debes verificar en tu servidor que tenga dos interfaces una para monitoreo y otra para la administración del dispositivo, debes crear una Sesión Rspan con un punto de Origen y un punto de destino (donde vas a entregar el Paquete capturado) esta sección encapsula el paquete original con la Vlan Remota y asi entregara el tráfico, es decir debes configurar la comunicación por toda la ruta de transmisión del paquete y al final crear una Sesión destino. a continuación te envío un documento muy interesante que te servirá de ayuda para solventar este problema.
https://www.google.com/url?q=https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_55_se/configuration/guide/3750xscg/swspan.html&sa=D&source=hangouts&ust=1611226570763000&usg=AFQjCNH9FrVZ_DYbukXBBPInwU7wFuRDqg
Recuerda Calificar la respuesta en la estrella, esto motiva a seguir contribuyendo en la comunidad.
