SRST CUCME -Register Selected Phones or DN's only
faizal_vi
I have an CUCME SRST setup. I have 100 phones registered with CUCM in my setup. My router has the capability to hold only 30 phones . In SRST mode I need only some selected dn's or phones to get registered.
What is the possible way to do it.....
Faizal
vasank
I haven't tried this but if you can  just configure the ephone-dn and ephone for the phones you want to register in srst mode under telephony service and this should do the trick...
cheers,
vasanth
Rob Huffman
Hi Faizal,
I believe the recommended method to accomplish this
is to create two Device Pools. One with a SRST reference
for the 30 required phones and one without a SRST reference
for the 70 other phones that you don't want to register
Assign the phones accordingly and you're good to go!
Cheers!
Rob
Thanks @Rob Huffman it was really helpful i had the same question.
Victorino
