SSL VPN options on 8941
SteveOrfanos
Level 5
Level 5
Hi All
Documentation seems to suggest that SSL VPN is not supported on the 8941. Is this correct, seems strange that all other handsets are supported.
Gordon Ross
Level 9
Level 9
The 8941 is a low(er) cost video enabled handset. Some features just aren't there.
GTG
Please rate all helpful posts.
5 Replies 5
Gordon Ross
Level 9
Level 9
GTG
Do we need CUCM 9.X for using VPN connection for cisco phone 8941 ?  please let me know.
CUCM 9.X --- ASA ----ssl vpn ---- 8941
I tested the SSL VPN on the 8941, that is fail.
On my 7942, that is working ...
Based on the release notes, you also have to install the latest device pack to enable the VPN functionality: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8941_8945/firmware/932/release_notes/P415_BK_RF066255_00_rn-9_3_2-8941-8945/P415_BK_RF066255_00_rn-9_3_2-8941-8945_chapter_00.html#P415_RF_V1A052E5_00
