StorageCraft Backup
JimEdmonds
We use StorageCraft (SC) backup for our enterprise which support RHEL 6.  We were interested in using SC to perform a full backup of our call manager which is on 11.5.1.  In order to install the SC solution we would need to drop down the RHEL root.  Is this not possible?  Is this not recommended?  We currently backup SFTP but the SC virtual boot is a nice feature that would get the call manager back online within a few minutes if we ever had the need.
Jaime Valencia
If you mean you need root access to a Linux appliance to modify or install anything, that is not possible nor supported.
java
if this helps, please rate
Jaime Valencia
java
