Strip Digits
Ali Norouzi
I defined below dial-peer on CME 7.1 to forward any number starting with 9 to PSTN. I want to to strip the 9 prefix and forward remaining 8 digits to PSTN line. But it doesn't strip and forwards all the 9 digits. I configured it in two way:
First
translation-rule 1
Rule 1 ^92 2
Rule 2 ^93 3
Rule 3 ^94 4
Rule 4 ^95 5
Rule 5 ^96 6
Rule 6 ^97 7
Rule 7 ^98 8
dial-peer voice 1 pots
destination-pattern 9[2-8].......
translate-outgoing called 1
port 0/2/0
prefix 9,
Second
port 0/2/0
prefix 9,
forward-digits 8
Remove the prefix 9. Also if you would go the path of translation rule you should use voice translation rules, translation rules are deprecated.
Please rate useful posts.
Response Signature
Use method 2, you do not need prefix command nor the forward-digits command as with pots dial-peers only explicitly matched digits are stripped, so in your case only 9 will be automatically stripped and remaining digits sent.
HTH,
Chris
