10-31-2013 05:56 PM - edited 03-16-2019 08:11 PM
Hey Guys
Is there a way to swap roles between two CUCM servers in a single cluster?
Pub to Sub and Sub to pub
Could you just do a physical move of the VMs and then re-IP them?
Any idea appreciated, cheers Mike
10-31-2013 06:02 PM
Mike,
That is not possible. Once a server has been defined as either Pub or Sub, it remains that for the life term of the system.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
10-31-2013 06:12 PM
Could you just move the VMs and then assigne new hostnames and IP addresses?
10-31-2013 06:43 PM
Read the above about moving VMs between hosts.
And yes, you can change the hostname and the IP of the servers, but that won't affect their role as Deji already mentioned.
Follow the guide on how to change IP/hostname available on CCO for your CUCM version.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
