09-16-2012 12:10 AM - edited 03-16-2019 01:13 PM
What are the length of the cables of the mic which come along with SX20?
Is there a way to extend the cable length of the mic?
What will be lenght of the second mic CTS-QSC20-MIC?
Suhail.
Solved! Go to Solution.
09-18-2012 09:38 AM
The microphones provided with SX20 / C20 / MX200 / MX300 are identical. The spare part number is CTS-QSC20-MIC=
This mic can also be used with an EX90.
The length of the attached cable is 7.5 meters; it has a 3.5mm plug on the end with 4 conductors (TRRS)
There is an extension cable, as mentioned. The part number is CAB-MIC20-EXT= and it is 10 meters long.
09-16-2012 06:57 AM
09-18-2012 04:54 AM
Thanks Srini. Great info.
09-18-2012 06:29 AM
Thanks Srini for the reply.
Can any one help me out in the extension cable? I have seen this part no CAB-MIC20-EXT=, will this work for SX20 mics?
09-18-2012 09:38 AM
08-02-2013 07:55 AM
Enrico,
Do you have any information regarding how many mic extension cables (CAB-MIC20-EXT=) can be daisy chained with the codecs?
08-05-2013 01:19 PM
Hi Chris -
The extension cable was designed to support only one length of 10 meters. Adding additional lengths may not work properly due to voltage drop.
If you need more length, I recommend using 22/4 shielded audio cable, which works fine up to 125 feet per a trusted partner. You will need to source 4 conductor 3.5mm male and female connectors.
.enrico
08-07-2013 06:44 AM
Thanks so much.
01-26-2015 09:55 PM
Hi Enrico,
Can you help if I want to use the mic input of SX10 so that I can use my wireless mic? Is this possible? Do I need a TRSS 3.5 input jack splitter where I can use the mic portion and input it to my wireless mic?
01-27-2015 08:19 AM
Hello - the SX10 does not support the use of third party microphones or mic systems. They actually won't work at all. The SX10 is a low cost settop device that is not designed for audio visual integration.
The SX20 is Cisco's entry-level integrator codec, supporting the use of third party microphone systems.
regards/
/enrico
sent from my largish iPhone 6
09-16-2012 01:47 PM
https://communities.cisco.com/thread/27697?tstart=0
**message from the moderator: please note that this URL is accessible only to Cisco Partners**
Thank you,
Rick Dahl
Cisco - CSE - Business Video
video or email: rdahl@cisco.com
Phone: 408.894.5112
Partner Communities is a great resource for reference, if you don't find, please ask!
https://communities.cisco.com/community/partner/collaboration/bizvideo
Call me on video – download Jabber for free https://www.ciscojabbervideo.com/rdahl@cisco.com//www.ciscojabbervideo.com/rdahl@cisco.com
Message was edited by: Kelli Glass
09-16-2012 01:55 PM
https://communities.cisco.com/message/96525#96525
**please note that the URL is accessible only to Cisco partners**
Thank you,
Rick Dahl
Phone: 408.894.5112
01-21-2015 01:17 PM
Enrico
Can the CAB-MIC20-EXT= also work with a SX10? I don't see why not since the same microphone also works with the SX10 but wanted to make sure in case there was a caveat with the SX10
01-21-2015 04:35 PM
There shouldn't be any additional caveat on extending an SX10 microphone with CAB-MIC20-EXT=. As usual, don't use more than one extension cable.
01-21-2015 04:39 PM
Thank you
Srini
