SX20 on CUCM 8.x 7.x
manuel-mendez
Does anybody know if we can register the SX20 as a 3rd party SIP endpoint in older versions of CUCM (prior to 8.6)? Otherwise, I guess my options are upgrading to 8.6 or get a VCS.
Manuel
21 Replies 21
I need to know also the answer of this question
Does that need a Single Screen licence or Multi Screen?
But I remember that I have configured sx20 with cucm 8.6 without any need for TP single screen license as it consume some DLUs only
May be this lic is required starting cucm 9
The license rule needs to be followed even in 8. Yes it takes DLU because user licensing isn't enforced
With 9 there is only one license called TP licensing that's all you need no more hassles with single multi etc
Srini
Hi Srini,
Thanks for your reply
So this one " LIC-TP-SGL-SRN " is now replaced with tp licensing ?
I found this license LIC-CTS-MAN-10=  also available for 50 and 100 units
Please advise what is the tp PN and I think I should use 2 for two sx20 .. right ?
Thanks again
Yes single screen with 8.
No cts man is needed that's the old scheduling product, TMS is the replacement product
Srini
sorry I got confused
Plz write the PN required for two sx20 with cucm 9
And If I install these 2 sx20 point to point, Do I need also this license
Thanks again Srini
Look under l-cucm-usr-LIC-add an inside that you will see the licensing
Yes for each unit you need to buy the license
Srini
for two sx20 with cucm 9.x you need:
Item NameDescriptionQuantity
R-UCL-UCM-LIC-K9Top Level SKU For 9.x/10.x User License - eDelivery1
LIC-TP-9X-ROOMTelepresence Room Based Endpoint Single or Multi-Screen2
CUCM-VERS-9.XCUCM  Software Version 9.X1
UCM-PAKUCM 9X/10X PAK1
