02-20-2018 09:58 AM - edited 03-17-2019 12:15 PM
Hello for everybody
I have CUCM 11.5 and two voice gateways connecting to PSTN ISR4431 and 3925E. For the outbound call I use Route List which contains two Route groups. Each Route Group contains SIP trunk to voice gateway. Today I tried to check redundancy and shutdown interface to the PSTN on the first gateway (4431) in Route List. Then I look debug ccsip mess on both gateways. CUCM sent Invite to the first gateway (4431) with shutdowned interface and after that gateway tried to sent more than 10 Invites although the interface is still shutdown and only after 2 minutes gateway sent "SIP/2.0 408 Request Timeout". Then CUCM took second trunk (3925E).
What can I do in this situation? How can I improve it?
Thank you
Solved! Go to Solution.
02-20-2018 10:35 AM
02-20-2018 10:08 AM
02-20-2018 10:35 AM
02-20-2018 10:53 AM
Mohammed thank you, it works faster, delay becomes to 7-8 seconds. Could you suggest how can I use TCP SIP? Which commands I sould use?
The suggest with option-ping is very interasting too. Do you have configutation example.
Thank you again
02-20-2018 02:59 PM
You can configure Options Ping on the CUCM.
Go to Device -> Trunk and find the SIP trunk that points to your gateway (CUBE).
Scroll down to the bottom and find the name of the SIP Profile on the Trunk.
Now go to Device ->Device Settings ->SIP Profile and find that same SIP Profile.
Scroll down to the bottom, and check the box named "Enable OPTIONS Ping to monitor destination status..."
You will need to Save and Reset the trunk, do this after hours.
After a few minutes, go back to Device->Trunk. The page should now show status "Full Service" and time since the last reset.
02-21-2018 12:21 AM
Ok, I understood, this option already enabled.
02-21-2018 12:31 AM
02-20-2018 02:01 PM
Have you turned on OOB options ping on each trunk, so cucm can flag it as down and go to the next trunk in the RG?
