Time Synchronization issue on CUCM with NTP Server (Cisco Router)
jahanzaib amin
Hello Experts,
We need your suggestion to configure Cisco 3800 Router as NTP Server and Syn with Cisco Call Manager to show correct time order on Cisco IP Phones.
There was a NTP Server before which is remove now but IP Phones are showing 30 min off from the Actual time.
We did Cisco 3800 as NTP server and added in CUCM as NTP Server but still time is showing different on Cisco IP Phones.
Please assist.
30 Replies 30
Manish Prasad
Level 5
Level 5
Can you please share output of "utils ntp status"
Manish
Aman Soi
Hi Amin,
Can u share the output of command from Publisher ?
utils  ntp status
Secondly,after u added new NTP reference in call manager, did u restart using command utils ntp restart.
regds,
aman
Hello Experts,
Here is output of the command:
SUB
ntpd (pid 19311 19005) is running...
     remote           refid      st t when poll reach   delay   offset  jitter
*127.127.1.0     127.127.1.0     10 l   34   64  377    0.000    0.000   0.015
synchronised to local net at stratum 11
   time correct to within 11 ms
   polling server every 64 s
Current time in UTC is : Sun Dec  1 06:46:13 UTC 2013
Current time in Mideast/Riyadh89 is : Sun Dec  1 09:53:17 zzz 2013
PUBLISHER
admin:utils ntp status
ntpd (pid 15948 15947 15623) is running...
127.127.1.0     127.127.1.0     10 l   30   64  377    0.000    0.000   0.008
*172.16.7.2      127.127.1.0     11 u   11   64  377    0.191    0.086   0.011
synchronised to NTP server (172.16.7.2) at stratum 12
   time correct to within 21 ms
Current time in UTC is : Sun Dec  1 06:44:40 UTC 2013
Current time in Mideast/Riyadh88 is : Sun Dec  1 09:51:44 zzz 2013
Any phone ntp references in date/time group ?
Manish
Hello Manish,
Can you calrify This point ? "Any phone ntp references in date/time group ?
System - Phone NTP References.
System - Date/Time Groups - xx_DTGrp - Phone NTP References.
Hi Amin,
I was just refering the line from  SRND which says
Cisco highly recommends configuring the publisher to point to a Stratum-1, Stratum-2, or Stratum-3 NTP server to ensure that the cluster time is synchronized with an external time source.
can u run the command in Publisher
utils diagnose module ntp_stratum  and share the output.
utils diagnose test
regds,
aman
Hello Aman,
Here is the output:
admin:utils ntp restart
Restarting NTP
ntpd (pid 26616) is running...
127.127.1.0     127.127.1.0     10 l   14   64    3    0.000    0.000   0.008
*172.16.7.2      127.127.1.0     11 u   53   64    1    0.206    0.001   0.015
   time correct to within 22 ms
   polling server every 16 s
Current time in UTC is : Mon Dec  2 05:07:27 UTC 2013
Current time in Mideast/Riyadh88 is : Mon Dec  2 08:14:31 zzz 2013
admin:
admin:utils diagnose module ntp_straum
Log file: /var/log/active/platform/log/diag1.log
Starting diagnostic test(s)
Diagnostics Completed
admin:utils diagnose test
Log file: /var/log/active/platform/log/diag2.log
test - disk_space          : Passed (available: 2324 MB, used: 10845 MB)
skip - disk_files          : This module must be run directly and off hours
test - service_manager     : Passed
test - tomcat              : Passed
test - validate_network    : Passed
test - system_info         : Passed (Collected system information in diagnostic log)
test - ntp_reachability    : Passed
test - ntp_clock_drift     : Passed
test - ntp_stratum         : Failed
The reference NTP server is a stratum 12 clock.
NTP servers with startum 5 or worse clocks are deemed unreliable.
Please consider using an NTP server with better startum level.
Please use OS Admin GUI to add/delete NTP servers.
How is the poll duration 16 Seconds is different from the polling server value of 64 Seconds ?
Hello Experts,
Time on CUCM is correct but its not forward to IP Phone..there is 6 mins difference on IP Phones.
Hi Amin,
Which version of CUCM you using ?
Are all  phones are getting date/time  by cucm or you are using some ntp reference in date/time group of that device pool ?
This is CM 6 and before we were using NTP Server but after removing the NTP Server the differene POP UP.
I will send the output in short while.
Hi Amin,
As asked by Prasad,please mention CUCM version and the model of IP phones which are facing the timing problem.
Did u ever try to reset Date/time group ?
regds,
aman
Hi Amin,
Just refer the link
After deleting, modifying, or adding NTP server, you must restart all the other nodes in the cluster for the changes to take affect.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/6_0_1/cucos/iptpch4.html#wp1042131
regds,
aman
