07-13-2015 02:26 AM - edited 03-17-2019 03:38 AM
Dear Team,
I want to change the timezone in CUCM 10.5 but following commands are not working:
show timezone list
show timezone 232
Please advise
12-20-2016 07:14 AM
Hi Mohit,
I'm having problem installing the file ciscocm.dst-updater.2015g-el6-00.11.0.1.cop
There is any services that I should shut down for it?
The SDKList.txt file doesn't exist. Please re-run the tool with -Ddiscoveronly=true option to generate the list of SDKs.
[Capture]
[Capture] --------------------------------xxxxxxx---------------------------------
[Capture] Removing the IBM JTZU temp directory
OS execution complete
Executing Product component
12-20-2016 07:07 PM
Which Call Manager version are you running?
++ Also check "Special Pre-Installation Instructions" & "Installation Instructions" in the read me file
Located here http://www.cisco.com/web/software/282074298/130428/dst-1101-2015g-cop-readme.pdf
It says "Before installing this DST COP file you must install ciscocm.RTMTTz-updater.2015g-el6-00.11.0.1.cop.sgn or be running a release that contains CSCuw64866" - DST/TZ data upgrade with 2015e - RTMT.
In the "Installation Instructions" I could see following
This package will install on the following System Versions: - 11.0.1.10000 - 10 or any higher version starting with 11.0.1.xxxx
