03-26-2010 09:15 AM - edited 03-15-2019 09:59 PM
hi everyone
The question is: why called party name is dispalyed when DN is dialed directly and is not displayed when it dialed throught translation pattern? And is there any way to correct this situation?
My CCM is 4.2.3 It seems like there is no suitable option in Service Parameters( Thank you in advance
03-26-2010 11:13 AM
Where is Called Party Name displayed for you now? Do you mean Calling Party Name? What does it look like now in both situations, and how do you want it to appear?
03-26-2010 11:28 AM
Phone 1 can call Phone 2 directly on number 5555 or throught translation
pattern 6.5555 which discards predot digits and then call phone 5555.
Let the Alerting Name on phone 2 be "User 2".
There are two scenarious:
1 When I dial 5555 from phone 1 I can see on my phone phone "User 2" and DN of phone 2
2 When I dial 6.5555 from phone 1 I can see only DN of phone 2. So Alerting name field is not dispalyed.
03-26-2010 11:35 AM
What do you have the 'Calling Name Presentation' setting on the translation pattern set to?
Try setting that to 'Allowed'.
Aaron
Please rate helpful posts..
03-26-2010 12:32 PM
It is set to Default which is allowed in my case(I've checked in Service
parametres)
The thing you are telling will fix another problem. Your option (taken from "help":
Choose whether you want the Cisco Unified CallManager to allow or restrict the display of the calling party's phone number on the called party's phone display for this translation pattern.
I have a different trouble: Called party number only is displayed on calling party's display when calling throught Translation pattern while calling directly to DN shows both DN and alerting name fields on my display.
03-26-2010 11:41 AM
Well, I can tell you that it works as you would like it to work in version 6.1.4. I would chalk this up to a software version that is 4 major revisions out of date and hasn't even been patched in a year and a half.
03-26-2010 12:33 PM
Probably it so( . Will try to check it somewhere on CUCM newer then my one.
