08-22-2012 02:16 AM - edited 03-16-2019 12:48 PM
Hi I have in a CUCM 8 a Translation-pattern to a internal extension, this fails and the debug shows ´Unallocated/unassigned number´
That extension is registered, and without any problem, i even test the TP with other extension, and fails again.
The call from CUCM to the remote site go through h323 trunk to a CME-SRST site.
ISDN channel are well, and outbound calls runs properly, this is the sh isdn status:
Global ISDN Switchtype = basic-net3
ISDN BRI0/0/0 interface
dsl 0, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
ISDN BRI0/0/1 interface
dsl 1, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Active dsl 1 CCBs = 0
And the debug isdn q931
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x82
Preferred, B2
Calling Party Number i = 0x2183, '6xxxxxxxx'
Plan:ISDN, Type:National
Calling Party Number i = 0x0183, '6xxxxxxxx'
Plan:ISDN, Type:Unknown
Called Party Number i = 0xA1, '91xxxxxxx'
*Aug 22 09:05:42.448: ISDN BR0/0/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xB4
Channel ID i = 0x8A
Exclusive, B2
*Aug 22 09:05:42.464: ISDN BR0/0/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xB4
Cause i = 0x8081 - Unallocated/unassigned number
*Aug 22 09:05:42.620: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8 callref = 0x34
*Aug 22 09:05:42.620: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xB4
I have other Translation-pattern to other extension but in other sites from cluster and all works fine, why this is failing?
The dial-peer are:
dial-peer voice 100 pots are (only put one for BRI)
dial-peer voice 1 pots
preference 1
destination-pattern 0T
port 0/0/0
dial-peer voice 20 pots
destination-pattern 06........
port 0/0/0
forward-digits 9
dial-peer voice 10 pots
preference 1
destination-pattern 09........
port 0/0/0
forward-digits 9
incoming called-number .
direct-inward-dial
port 0/0/0
port 0/0/0
forward-digits 9
preference 1
port 0/0/0
forward-digits 9
direct-inward-dial
port 0/0/0
Into CUCM/DNA show it runs, which could be the cause of this problem??
Thanks!!
Solved! Go to Solution.
08-22-2012 06:24 AM
I only see POTS DPs there, where are the VOIP DPs which are the ones you should be interested in??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
08-22-2012 04:04 AM
Ivan,
This is usually caused by a wrong CSS assigned to the translation pattern. You need to ensure that the CSS on the translation pattern has access to the devices its trying to reach. So check the CSS on it.
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
08-22-2012 04:26 AM
Hi!
No matter what extension I put in the translation-p , always fails, outbounds calls runs well, only fails inbound.
I have checked CSS but seems fine, have all partition asigned.
thanks.
08-22-2012 04:34 AM
Ok. Can you send a screen shot of your translation pattern.
This is what you should have . (random example)
Translation Pattern: XXXXXX
parttition: PT_YYYY
CSS: CSS_ZZZ
Called party transform mask: 7000XXX
1. The CSS on your gateway has acess to the Partition of the Xlation pattern
2. The CSS on your xlation pattern has access to the partiton of your called party xform mask
3. Configure your called party xform mask correctly
If you send a screen shot, called and transformed mask I am sure we can fix this
08-22-2012 06:24 AM
java
08-23-2012 01:16 AM
Hi!
Finally was resolved the problem, was a dial-peer voip, the call enter in the Router, but it does not know what to do with that number because is associated a extension registered via wan in the CUCM, so in the dial-peer voice voip needed to put as destinattion-p the number of the TP.
dial-peer voice 1234 voip
session-target: ip CUCM
destination-pattern ---> the telephony number of the basic header, and the TP number.
Thanks!!!!
