TranslatorX
Oleg Serstjuk
anyone having an issue with opening Exported Files with TranslatorX?
I generate call filters for a particular call - select Export Details - save a file to have one call as one file(to save adding the filters again and waiting for details to generate if its a very large file)
When I go to reopen this file in translatorX - it only loads the whole file as one message
Tried pasting direct from the text file into translatorX and same issue
I compared the messages from exported file and message in SDL file and they are identical
5 Replies 5
Dennis Mink
you saying, when you use RTMT and filter the call log on one call, save it, then open that file in TranslatorX, you see other calls in that file as well?
If so, that is normal
Please remember to rate useful posts, by clicking on the stars below.
collect files using RTMT
Open in TranslatorX
use filters to find the call
select Export Details - file gets saved with only the call that was filtered out
then when you try open the exported file in TranslatorX, it opens the whole file as one 1st messagex.jpg
Just got a response from the translatorX team
Re-importing the exported details files is not supported yet
It's on their to do list
Is it possible that the current version isn’t working with Cisco Callmanager Version 12.x?
TranslatorX Version = 11.5(2) build 5
Cisco Callmanager = 12.0.1.21900-7
If I try to open the calllog files (e.g: calllogs_00000019.txt.gz) I got an error message. If I open it with the notepad I can read the log.
did you get this resolve? Not sure why this program can't open .txt, ,gz logs?
