Trunk SIP between CCM 4.1(3) and Asterisk 1.2 codec G729
atorresmolina
Hello
We have a trunk SIP between CCM 4.1(3) and Asterisk 1.2 working fine with codecs g711u/g711a.
We want to change the trunk's codec to g729 for WAN link.
Incoming calls (from asterisk to ccm) work fine (profile mtp (cisco 2801) or profile xcode) with g729 throught trunk sip.
The regions are properly configured to allow this scenario.
Outgoing calls (from ccm to asterisk) don't work with g729, only with g711.
Do you know if it's possible to place calls from ccm to asterisk throught trunk sip in g729 ?
Here you are the logs on ccm when the call failed (capability mismatch !!!! and ERROR - no resources are available )
What kind of resources CCM need to work?
Why work g729 on incoming calls and not in outgoing calls?
Thanks for your time
11/22/2006 19:47:30.890 CCM|MediaTerminationPointControl - ERROR AllocateMtpResourceReq failed - CAPABILITY MIS-MATCH -- Ci = -2130704288|<CLID::StandAloneCluster><NID::x.x.x.x><CT::1,100,119,1.8341><IP::x.x.x.x><DEV::SEPxxxx>
11/22/2006 19:47:30.890 CCM|MediaTerminationPointControl(90)::waiting_AllocateMtpResourceReq - ERROR ActiveCap - mismatch cap|<CLID::StandAloneCluster><NID::x.x.x.x><CT::1,100,119,1.8341><IP::x.x.x.x><DEV::SEPxxxx>
11/22/2006 19:47:30.890 CCM|MRM::waiting_AllocateMtpResourceErr - ERROR - no resources are available -- ci = -2130704288|<CLID::StandAloneCluster><NID::x.x.x.x><CT::1,100,119,1.8341><IP::x.x.x.x><DEV::SEPxxxxx>
11/22/2006 19:47:30.890 CCM|ConnectionManager - wait_AuDisconnectRequest:NO ENTRY FOUND IN TABLE,CI(16777934,0),dcType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)|<CLID::StandAloneCluster><NID::x.x.x.x><CT::1,100,119,1.8341><IP::x.x.x.x><DEV::SEPxxxxxx>
5 Replies 5
msolak
Level 4
Level 4
With CM 4.x the codec for all calls established over a given sip trunk is restricted to either G.711 mu-law or a-law.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_implementation_design_guide_chapter09186a00806e8c64.html#wp1049854
regards
mehmet
Thanks for your answer
Incomings calls from asterisk to ccm 4.x work in g729 with mtp resource or xcode in 2801, depending of the regions and device pool configuration.
How is it possible if ccm 4.x only work with g711 over trunk sip ?
Thanks a lot
hey,
not to overtake the thread, but could you explain the details on how you have this working? i ask because i have a customer that wants to do the same thing
thanks
There is a nice document in voip-info.org.
Take a look
http://www.voip-info.org/wiki/view/Asterisk+Cisco+CallManager+Integration
If you has any doubt contact me again.
Cheers
I've had more success in getting an H323 link up between Asterisk and CCM. Supports both G711 and G729 without requiring transcoding at the CCM gateway end. (G729 requires licenses on the * side though).
Was pretty easy to get going but i've yet to write up my notes on this.
