IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5907 Views
  • 14 replies
i am facing one issue with one cisco ip phone 7960 regarding call forwarding .my ccm server is 4.1.3 versioni am attaching the cdr error report and normal cdr report with this. normaly call type is simple in cdr . but in the error phone i am getti...
Trying to change the MOH on Directory numbers. Go to update phones, add directory number. "Add to Query" under Paramiters select "User hold audio source" go to value select "source" then "Set Value" check reset devices. At this point I can view resul...
pharden by Level 1
  • 592 Views
  • 2 replies
