Trying to Configure and FXS but dont know how
Im trying to configure a FAX in a FXS module but i want to know first in which FXS port my machine is connected.
Any light, any protocol or line changes to up when i connect my FAX?
Please help me! how to troubleshoot an FXS
FXS interfaces are connected to voice-ports in CLI config.
voice-port 1/0 is the FXS 1/0
The led cards is on only during calls.
You can also use the command "sh voice call summary" to see the used port:
PORT           CODEC    VAD VTSP STATE            VPM STATE
1/0             -         -  -                     FXSLS_ONHOOK
1/1             -         -  -                     FXSLS_ONHOOK
2/0             -         -  -                     FXSLS_ONHOOK
2/1             -         -  -                     FXSLS_ONHOOK
During calls the status will change to OFF HOOK.
Regards.
