ā02-01-2012 11:48 PM - edited ā03-16-2019 09:21 AM
I'm trying to understand/configure early media for 15.0(1)M4. From what I understand so far it is media which is played to the caller before a (SIP) session is established. In our situation we need to play a certain audio file when someone calls a particular phone number.
What I do not understand is how and where I need to configure this audio file which needs to be played? Is it something I have to configure in our Cisco 3925 or do I need to tell our SIP provider to do the early media for us?
Any help would be useful.
ā02-02-2012 12:09 AM
How you play an audio file to a caller depends on the specifics of the system you got, and that you haven't mentioned (saying have a router is not enough). There are different ways to do that.
Note it has nothing to do with early media, and is normally not done by your ITSP.
ā02-02-2012 12:14 AM
We are currently focused on developing VoiceXML applications which reside on our router. One of the VoiceXML applications plays an audio file and then transfers the caller to another destination. This audio file plays "This call costs x cents per minute". From what I understood this should be played before the connection is established between the caller and the VoiceXML application, so that the caller is not billed during the playing of the file.
ā02-02-2012 12:23 AM
Your script is responsible to do that using the events and the commands available in TCL/IVR.
It is also responsible to complete the connection at a certain , thereby billing to the caller.
ā02-02-2012 12:33 AM
Alright, thank you.
Is there an alternative way to accomplish this? I'm just trying to find the options we have, before I decide to go the TCL way.
ā02-02-2012 12:41 AM
There can be more ways but one would have to know many more details about the specifics requirements and budget of your project.
ā02-02-2012 01:14 AM
What is early media actually used for, since I'm hearing different things from different sources? Some say it's used to establish a media path prior to the connection between the caller and called being established. When I read this I thought of this is exactly what we need, but I hear from you early media has nothing to do with this.
ā02-02-2012 02:15 AM
It may have to do with it. In you first posts you did not specified that the announcement has to be played before connect, from that my answer.
ā02-02-2012 02:32 AM
Ah my bad. Yes, an announcement must be played before connect.
Below a part of my tcl script. Is this the correct way to achieve the early media? I've attached the debug ccsip all to the original post.
proc act_Setup { } {
puts "Received an incoming call"
leg setupack leg_incoming
leg proceeding leg_incoming
leg progress leg_incoming
puts "Playing media"
media play leg_incoming flash:cost.wav
leg connect leg_incoming
ā02-02-2012 09:12 AM
Early offer/early media are very confusing, and may or may not apply to this situation, but here is some explanation from the SRND - follow the link to read the whole chapter, it has some good discussion you don't find many other places:
Early Media
In certain circumstances, a SIP session might require that a media path be set up prior to the finalization of the media capabilities exchange between the two SIP endpoints. To this end, the SIP protocol allows the establishment of Early Media after the initial Offer has been received by an endpoint. Some reasons for using Early Media include:
ā¢The called device might want to establish an Early Media RTP path to reduce the effects of audio cut-through delay (clipping) for calls experiencing long signaling delays or to provide a network-based voice message to the caller.
ā¢The calling device might want to establish an Early Media RTP path to access a DTMF or voice-driven interactive voice response (IVR) system.
Unified CM supports Early Media for both Early Offer and Delayed Offer calls.
For a SIP trunk to support Early Media cut-through, you must enable PRACK through the SIP Rel1XX Options feature in the SIP Profile associate with the trunk.
Note The terms Early Offer and Early Media are often confused, but they are not the same.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/trunks.html
Mary Beth
ā02-23-2012 01:13 AM
Sorry for my late reply. I've been busy with some other things.
I've managed to build a tcl script which plays an announcement before the call is actually connected.
Could someone please inspect the debug ccsip messages file which I've added to the original post to confirm this is really early media?
ā08-30-2017 05:22 AM
From the debugs you sent, I can see confirm media is advertised in a provisional message and accepted. We'd need more detailed debugs to know if this actually resulted in the file being streamed as early media, but in theory, it is working.
I have a similar requirement. Is it possible for you to share this script?
- Jonathan
