Two Calling party number issue
Petr Nyvlt
I have an issue with incomming calls on E1 line from specific sites abroad .
From time to time we receive in call SETUP two different Calling Party Numbers  .
For example:
Calling Party Number i = 0x0080, \'00492155762497\'
Calling Party Number i = 0x0083, \'00492155760\'
I have an information from provider that the first number (0x0080) is the Calling Party Number
and the second (0x0083) is Generic Number (Additional Calling Party Number)
I found that the second number should be used in case you wish to use a different presentation/display number than the 'main' number. It may, for example, be a direct dial-in extension number of calling operator.
The issue is that this number is incorrect and it is displayed as calling DN on IP phones.
I need to ignore that and use the original Calling Party Number (0x0080).
Is there some solution how to set up the gateway for that?
Thank you for any suggestions.
Manish Gogna
Hi Petr,
This clearly looks to be an issue from Telco, they should be sending just one calling party i for one call setup. Rather than trying to fix it on your gateway you should ask the Telco to fix this at their end.
Manish
Hi Manish,
According to information from provider, this is not incorrect SETUP message.
The second number is Generic Number (Additional Calling Party Number). I thing it should be possible to handle with that on cisco gateway.
Although I agree with Manish, you can check with following command under serial interface;
isdn callling-party-num {network-provided | user-provided} {first | last}
Please check with above combinations and see if it serves your purpose.
- Vivek
it worked for me, thanks !
my Telco is sending both local and international format, so we picked the local one
May 30 12:20:03: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x5781
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0x0080, '9655071XXXX'
Plan:Unknown, Type:Unknown
Calling Party Number i = 0x0083, '5071XXXX'
Called Party Number i = 0x81, '320'
Plan:ISDN, Type:Unknown
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn calling-party-num network-provided second
