08-22-2017 07:07 PM - edited 03-17-2019 11:02 AM
Hello All,
Trying to delete a user mailbox in Unity Connection version10.5. I used the SQL command to find the Objet ID but failed to delete the user. I also used the Bulk User Delete tool to trace the dependencies but no dependency was found. Pleas see the attached document for the steps I have gone througth.
Is there anything else that I can do to delete the user mailbox?
08-23-2017 06:31 AM
Anybody with any idea?
MK
08-28-2017 06:40 AM
I guess I need to go ahead and open a TAC case for this.
MK
08-28-2017 11:06 AM
Try the CUDLI tool for a view of how data within the CUC tables relate. Looks like this user account is referencing or being referenced by something in the scheduleset table.
http://www.ciscounitytools.com/Applications/CxN/CUDLI/CUDLI.html
Brandon
08-28-2017 12:33 PM
Hi Brandon,
I was able to find an entery in the DB for 038eded1-5092-4b42-9974-5e4a14eb47bb ObjectID using the CUDLI tool . Please see the attached file.
Now, I need to find the alias for the ObjectID which is being used as a reference. Tried the follwoing query with no luck.
run cuc dbquery unitydirdb select alias from vw_user where objectid = 'e711002-6474-4a85-ae2d-1cc1ce97013d'
Could you please advise?
MK
08-28-2017 12:35 PM
08-28-2017 12:52 PM
Looks like this is referencing a notification device. Can you try deleting all notification devices for this user and then try to delete the user again?
08-28-2017 01:03 PM
The notification devices are all disabled. The delete boxes are grayed out.
Notification Devices Status Display Name Type Destination Phone System
Delete SelectedAdd New | ||||
Disabled | Pager | Pager Device | ||
Disabled | Mobile Phone | Phone Device | ||
Disabled | Home Phone | Phone Device | ||
Disabled | Work Phone | Phone Device | ||
Disabled | SMTP | SMTP Device | ||
Disabled | HTML | HTML Device | ||
MK
08-28-2017 01:23 PM
Do any of the notification devices have a destination configured?
08-28-2017 01:31 PM
At the begining the SMTP was enabled with an email adress but I deleted the email adress and disabled the device. There's no destination configured on any of the devices at the moment.
Disabled | Pager | Pager Device | Destination | Phone System |
08-28-2017 01:43 PM
OK. Sounds like a TAC case. I feel like there is some relation to the notification device entry in the database. This will likely need to be deleted.
08-28-2017 01:44 PM
Thanks Brandon, I really appreciate your time.
MK
08-28-2017 02:07 PM
Brandon,
Is there an SQL query that I can run to get the alias knowing the ojectid? I tried the following but no luck:
run cuc dbquery unitydirdb select alias from vw_user where objectid = 'd9922775-cf51-47e8-8e20-c754b00948f8'
MK
08-28-2017 10:09 PM
08-29-2017 09:11 AM
Yes Brandon, you are right. The object ID wasn't a valid one. The query returns the cortect alias as long as the objectid is valid.
Thanks again,
MK
