09-27-2012 12:19 PM - edited 03-16-2019 01:26 PM
I have a UC520-16U-4FXO-K9, the integrated 4 fxo works 100% fine.
I have try to add another FXO card with 2 port. ( VIc card ) and I cant see the ports in the CLI.
note : the Led of the FXO are organge, I allready try to use another FXO card but same result.
Anyone knows why ?
here is the details of the show inv and sh diag
thanks guys :
sh ver
Version 12.4(11)XW
flash:uc500-advipservicesk9-mz.124-11.XW4
10 FastEthernet interfaces
2 terminal lines
4 Voice FXO interfaces ( should be 6 - 4FxO and 2 FxO )
4 Voice FXS interfaces
1 Voice MoH interface
1 cisco service engine(s)
UC520#show inv
NAME: "UC520-16U-4FXO-K9 Chassis", DESCR: "UC520-16U-4FXO-K9 Chassis"
PID: UC520-16U-4FXO-K9 , VID: V01, SN: FHK114215GT
UC520#sh diag
Slot 0:
UC500 Mainboard 1FE, 8FE POE, Stacking FE, MOH, Port adapter
Port adapter is analyzed
Port adapter insertion time unknown
Hardware Crypto Engine Details:
The CHIP id is 0x10003
The SEC revision no is 0x1
EEPROM contents at hardware discovery:
PCB Serial Number : FOC11343WZB
Hardware Revision : 2.2
Top Assy. Part Number : 800-29314-01
Board Revision : C0
Deviation Number : 0
Fab Version : 02
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : AD
Hardware date code : 0
Chassis Serial Number : FHK114215GT
Chassis MAC Address : 001b.8fab.48a0
MAC Address block size : 32
CLEI Code : TBD0000000
Product (FRU) Number : UC520-16U-4FXO-K9
Part Number : 73-10819-02
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
FXO Voice IO Card:
Hardware Revision : 3.1
PCB Serial Number : FOC11416M8P
Part Number : 73-10820-03
Board Revision : D0
RMA History : 00
Top Assy. Part Number : 800-28035-02
CLEI Code :
PVDM Slot 0:
32-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8539-05
Board Revision : B0
Fab Version : 04
PCB Serial Number : FOC11374HZF
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-32
VIC Slot 0:
3rd generation - FXS DID Voice daughter card (4 port)
Hardware Revision : 1.0
Top Assy. Part Number : 800-27474-02
Board Revision : D0
Fab Version : 01
PCB Serial Number :
RMA History : 00
Product (FRU) Number : VIC3-4FXS/DID
CLEI Code : TBD
Longitudinal Calibration : 01 10 10 A4 8E 10 10 76
64 10 10 7D 67 10 10 7A
A2
VIC Slot 1:
2nd generation - FXO Voice daughter card (4 port)
Hardware Revision : 5.0
Top Assy. Part Number : 800-21589-02
Board Revision : A1
Deviation Number : 0-0
Fab Version : 04
PCB Serial Number :
RMA History : 00
Product (FRU) Number : VIC2-4FXO
CLEI Code : CNUIAPRAAA
VIC Slot 2:
Unknown WAN daughter card
Unknown EEPROM ver 176
EEPROM format version 176
0x20: B0 80 FF FF FF FF FF FF 00 1E FF FF FF FF FF FF
0x30: 90 0A FF FF FF FF FF FF FF FF FF FF FF FF FF FF
VIC Slot 4:
One port MOH Voice Interface
Built-in 9 ports Ethernet Switch with ILP Support for 8 ports
Hardware: Marvell 88E6083 Chip Revision: 1
LTC4258 PoE controller#0:
IC version: 0x4 Firmware revision: 0x0 Silicon revision: 0x0
LTC4258 PoE controller#1:
Onboard Service Engine: 0
Solved! Go to Solution.
09-27-2012 01:55 PM
Philippe,
You need a VIC2 type card.
The VIC type hardware is older and not supported.
Sorry
Alex.
Please rate useful posts.
09-27-2012 01:42 PM
Philippe,
Your router is not recognising your fxo hardware
Check you are using card from this table:-
Modular Support
Table 6 lists available modules and interface cards supported in the open slot.
Table 6. Modules and Interface Cards Supported in the Open Slot
Feature Benefit
VIC-4FXS/DID, VIC3-4FXS/DID 4-port VIC-FXS/DID (note that VIC3-4FXS/DID requires Cisco IOS Software release 12.4(20)T or later)
VIC2-FXS 2-port VIC-FXS
VIC2-2FXO 2-port VIC-FXO (universal)
VIC3-2FXS/DID 2-port VIC-FXS/DID (note that VIC3-2FXS/DID requires Cisco IOS Software release 12.4(20)T or later)
VIC2-4FXO 4-port VIC-FXO (universal)
VIC2-2BRI-NT/TE 2-port VIC card-BRI (NT and TE)
VWIC2-1MFT-T1/E1 1-port VWIC-T1/E1 for voice (ISDN PRI and CAS) - data is not supported
Alex.
09-27-2012 01:51 PM
Acampbell,
There is a sticker on it ; VIC-2FXO,... ( also : 800-02495-01FO )
from your table you have VIC2-2FXO but not VIC-2FXO ... I guess this should be the problem !? what do you think ?
09-27-2012 01:55 PM
Philippe,
Sorry
Alex.
09-27-2012 02:05 PM
Sounds good, Thnaks
