UCCX 8 Backup Error
Elie Bassil
I have a problem with the UCCX which displays error on the Backup page as per the attached:
•    UCCX System version: 8.0.2.11003-10
•    Installed on  Linux
admin: show version active
Active Master Version: 8.5.1.10000-26
Active Version Installed Software Options:
No Installed Software Options Found.
Note that the screenshot is a new status: ( the old one was showing “backup in progress” always for two weeks )
Jonathan Schulenberg
Have you tried restarting the Cisco DRF Master and Cisco DRF Local services? It's on the Cisco Unified Serviciability UI Tools > Network Services menu.
Like Jonathan said, restart these two services from Network services...if not i have seen sometimes you have to reboot the server to clear this up...
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Ok thanks I will try that, but will restarting those services have any effect on the system? Will there be any downtime?
10x,
E.B:.
No, restarting the DRF services will not be service impacting, at least in theory.
