uccx application user and password.(urgent)
waqas sardar
Dear Team ,
One of the client have forgot the username and password of the UCCX application.
I tried to find in CUCM enduser but failed as there is no proper description for the UCCX.
Can you please guide me ,how to find the uccx application user and password (i thinkg from cucm enduser).
8 Replies 8
Aaron Harrison
What version of CCX?
There's nothing special about the user in CUCM that would allow you to find it.
From the UCCX server CLI, you can run this to see the 'AppAdmin' username, then reset the pw in CUCM:
show uccx appadmin administrators
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
System version: 8.5.1.10000-37
this command is not available ?
By changing the password ,it wll effect any thing?
It may not be available on your version, I'm on 8.5.1.11003-32 and it is.
The password should not affect anything else.
You could try instead setting a new appadmin user with ''set uccx appadmin administrator'
Aaron
admin:show ucc
admin:show uccx
      show uccx cad*
      show uccx components
      show uccx dbcontents
      show uccx dbschema
      show uccx dbserver*
      show uccx dbtable*
      show uccx jtapi_client*
      show uccx license
      show uccx provider*
      show uccx recordings*
      show uccx servm*
      show uccx subcomponents
      show uccx tech*
      show uccx trace*
      show uccx version
admin:set uccx
      set uccx cad*
      set uccx provider*
      set uccx trace*
this command is also not available ?
Any other solution pls?
OK - what about these:
utils reset_application_ui_administrator_name
utils reset_application_ui_administrator_password
Aaron
These are available but by changing both username and password may effect the IVR or Agent as server is in production ?
The command sets a new administrator - since you don't know the current administrator there's nothing more to break?
Aaron
