UCCX: Error encountered: The selected file is not valid. MD5 Hash Value: -
Sergey Lubenkov
I have BE6000 and just completed CCM, CUC and CUP upgrade from 9.1 to 11.5.
However when I am trying to run UCCX upgrade I am getting the following error:
"Error encountered: The selected file is not valid. MD5 Hash Value: -  "
I've tried to reinstall "ciscocm.version3-keys.cop.sgn" file and  tried to restart UCCX but that didn't work.
Then I've tried different images ("UCSInstall_UCCX_11_5_1_UCOS_11.5.1.11001-34.sgn.iso" and "UCSInstall_UCCX_11_6_1_UCOS_11.6.1.10000-51.sgn.iso") but still getting that error.
Does anybody know what could be the problem?
Thank you
7 Replies 7
Leo Laohoo
That error message means the file is corrupt.  Maybe the download process got interrupted and the file is not complete.
you can use FastSum utility [goggle.com] to check MD5 value. you can compare the executed value with what is available on cisco site from where u are downloading image.
regds,
aman
Verified. MD5 value is correct.
I thought about that, but I've tried 2 different download of "UCSInstall_UCCX_11_5_1_UCOS_11.5.1.11001-34.sgn.iso" and also "
UCSInstall_UCCX_11_6_1_UCOS_11.6.1.10000-51.sgn.iso".
Did you find answer to this issue? I'm having the same problem it seems
Hi there
Whats your upgrade path, if you are upgrading from  9.0(2)SU2/10.0(1)SU1 Releases you also have to install the refresh upgrade cop file (ciscouccx.refresh_upgrade_v1.11.cop.sgn) along with the (ciscocm.version3-keys.cop.sgn) on every node in the cluster.
please let me know if that helps
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
Yes upgraded to 9.0.2 SU3 (which I asssume must include the above) and upgrade to 11.6 is proceeding now
