04-26-2011 05:52 AM - edited 03-16-2019 04:40 AM
I can´t change the logo Cisco 7912 in the CME. I´ve following the configuration guide about documentation step convert the logo, to create the configuration file, to uploaded files available to the IP phones using the commands tftp-server flash, but still not work. The IP Phone reset default, then the IP Phone download the gkdefault.cfg, but don´t change the logo. Any idea?
TIA
Cristian
04-26-2011 07:28 AM
Logo on the 7912 is not the easier task however if it doesn't work, likey there is a mistake in you configuration file or .cfg conversion process.
04-26-2011 08:02 AM
Dear Paolo, thanks for your answer.
The steps were the follow:
2.- I converted using : bmp2logo 10 cisco.bmp cisco.logo
3.- I created a text file gkdefault.txt name and contain:
#txt
upgradelogo:10,0,cisco.logo
4.- I converted using : fgfmt.exe -cfgfmt gkdefault.txt gkdefault.cfg
5.- In the router flash, I created a folder 7912 name and I upload the gkdefault.cfg and cisco.logo files.
6.- I debugged the TFTP and I saw the 7912 ask for United_States/gkdefault.cfg when go reset default (menu, **2, yes). I added two the follow command:
tftp-server flash:/7912/gkdefault.cfg alias United_States/gkdefault.cfg
tftp-server flash:/7912/cisco.logo alias United_States/cisco.logo
My doubt is How does the 7912 where is the cisco.logo file? I suspect missing something but there no document about.
TIA
Cristian
04-26-2011 02:01 PM
More information. This is the debug with reset starting 7912. I can´t see where ask for cisco.logo file.
CME#
*Apr 26 21:08:27.355: TFTP: Server request for port 14815, socket_id 0x87D4D370 for process 153
*Apr 26 21:08:27.355: TFTP: read request from host 10.10.10.21(14815) via Vlan10
*Apr 26 21:08:27.355: TFTP: Looking for SEP001B0C964AA9.cnf.xml
*Apr 26 21:08:28.091: TFTP: Opened system:/its/vrf1/XMLDefault7912.cnf.xml, fd 10, size 964 for process 153
*Apr 26 21:08:28.091: TFTP: Sending block 1 (retry 0), socket_id 0x87D4D370
*Apr 26 21:08:28.103: TFTP: Received ACK for block 1, socket_id 0x87D4D370
*Apr 26 21:08:28.103: TFTP: Sending block 2 (retry 0), socket_id 0x87D4D370
*Apr 26 21:08:28.115: TFTP: Received ACK for block 2, socket_id 0x87D4D370
CME#
*Apr 26 21:08:28.115: TFTP: Finished system:/its/vrf1/XMLDefault7912.cnf.xml, time 00:00:00 for process 153
*Apr 26 21:08:28.151: TFTP: Server request for port 14895, socket_id 0x87D4D370 for process 153
*Apr 26 21:08:28.151: TFTP: read request from host 10.10.10.21(14895) via Vlan10
*Apr 26 21:08:28.151: TFTP: Looking for United_States/gk001b0c964aa9
*Apr 26 21:08:28.151: TFTP: Sending error 1 No such file
*Apr 26 21:08:28.159: TFTP: Server request for port 14896, socket_id 0x87D4D370 for process 153
*Apr 26 21:08:28.159: TFTP: read request from host 10.10.10.21(14896) via Vlan10
*Apr 26 21:08:28.159: TFTP: Looking for United_States/gkdefault.cfg
CME#
*Apr 26 21:08:28.207: TFTP: Opened flash:/7912/gkdefault.cfg, fd 10, size 33 for process 153
*Apr 26 21:08:28.207: TFTP: Sending block 1 (retry 0), socket_id 0x87D4D370
*Apr 26 21:08:28.215: TFTP: Received ACK for block 1, socket_id 0x87D4D370
*Apr 26 21:08:28.215: TFTP: Finished flash:/7912/gkdefault.cfg, time 00:00:00 for process 153
CME#
*Apr 26 21:08:29.423: %IPPHONE-6-REG_ALARM: Name=SEP001B0C964AA9 Load=CP7912060100SCCP051208A Last=(null)
*Apr 26 21:08:29.523: %IPPHONE-6-REGISTER: ephone-1:SEP001B0C964AA9 IP:10.10.10.21 Socket:3 DeviceType:Phone has registered.
CME#
*Apr 26 21:08:31.871: TFTP: Server request for port 15031, socket_id 0x87D4D370 for process 153
*Apr 26 21:08:31.871: TFTP: read request from host 10.10.10.21(15031) via Vlan10
*Apr 26 21:08:31.871: TFTP: Looking for Ringlist.xml
*Apr 26 21:08:31.871: TFTP: Sending error 1 No such file
*Apr 26 21:08:31.879: TFTP: Server request for port 15032, socket_id 0x87D4D370 for process 153
*Apr 26 21:08:31.879: TFTP: read request from host 10.10.10.21(15032) via Vlan10
*Apr 26 21:08:31.879: TFTP: Looking for United_States/7960-tones.xml
*Apr 26 21:08:31.883: TFTP: Opened system:/its/united_states/7960-tones.xml, fd 10, size 903 for process 153
CME#
Please, need help!!...
04-27-2011 07:07 AM
Hi Cristian,
have you tried resetting the gateway? or running create cnf-files under telephony-service, also ensure you paths are correct.
conf t
telephony-service
create cnf-files
HTH,
Justin
04-27-2011 07:07 AM
Hi Justin
Yes, I reset the GW.Also I has created the cnf-files command.
Please, see the follow:
The path in the flash
156 0 Apr 21 2011 15:53:22 +00:00 7912
157 33 Apr 21 2011 15:54:38 +00:00 7912/gkdefault.cfg
158 308 Apr 26 2011 21:07:32 +00:00 7912/cisco.logo
The TFTP command
Help..help ..pls...
04-28-2011 01:17 PM
Hi guys, really I need help....:(
Any idea??
Cristian
04-28-2011 01:29 PM
I have not check, but maybe the "10" in config file is a revision number, have you tried increasing it ?
Chances are the generate .cfg file is not valid.
04-28-2011 02:04 PM
Hi Paolo
The new file have:
#txt
upgradelogo:20,0,cisco.logo
But, still not works.
CME#
*Apr 28 21:14:51.867: TFTP: Server request for port 2782, socket_id 0x87B3A160 for process 95
*Apr 28 21:14:51.867: TFTP: read request from host 10.10.10.22(2782) via Vlan10
*Apr 28 21:14:51.871: TFTP: Looking for SEP001B0C964AA9.cnf.xml
*Apr 28 21:14:52.603: TFTP: Opened system:/its/vrf1/XMLDefault7912.cnf.xml, fd 10, size 964 for process 95
*Apr 28 21:14:52.603: TFTP: Sending block 1 (retry 0), socket_id 0x87B3A160
*Apr 28 21:14:52.615: TFTP: Received ACK for block 1, socket_id 0x87B3A160
*Apr 28 21:14:52.615: TFTP: Sending block 2 (retry 0), socket_id 0x87B3A160
*Apr 28 21:14:52.623: TFTP: Received ACK for block 2, socket_id 0x87B3A160
*Apr 28 21:14:52.623: TFTP: Finished system:/its/vrf1/XMLDefault7912.cnf.xml, time 00:00:00 for process 95
*Apr 28 21:14:52.655: TFTP: Server request for port 2861, socket_id 0x87B3A160 for process 95
*Apr 28 21:14:52.655: TFTP: read request from host 10.10.10.22(2861) via Vlan10
*Apr 28 21:14:52.655: TFTP: Looking for United_States/gk
CME#001b0c964aa9
*Apr 28 21:14:52.655: TFTP: Sending error 1 No such file
*Apr 28 21:14:52.663: TFTP: Server request for port 2862, socket_id 0x87B3A160 for process 95
*Apr 28 21:14:52.663: TFTP: read request from host 10.10.10.22(2862) via Vlan10
*Apr 28 21:14:52.663: TFTP: Looking for United_States/gkdefault.cfg
*Apr 28 21:14:52.699: TFTP: Opened flash:/7912/gkdefault.cfg, fd 10, size 33 for process 95
*Apr 28 21:14:52.699: TFTP: Sending block 1 (retry 0), socket_id 0x87B3A160
*Apr 28 21:14:52.711: TFTP: Received ACK for block 1, socket_id 0x87B3A160
*Apr 28 21:14:52.711: TFTP: Finished flash:/7912/gkdefault.cfg, time 00:00:00 for process 95
*Apr 28 21:14:52.723: %IPPHONE-6-REG_ALARM: Name=SEP001B0C964AA9 Load=CP7912060100SCCP051208A Last=Initialized
*Apr 28 21:14:52.823: %IPPHONE-6-REGISTER: ephone-1:SEP001B0C964AA9 IP:10.10.10.22 Socket:1 DeviceType:Phone has registered.
*Apr 28 21:14:53.983: TFTP: Server request for port 2993, socket_id 0x87B31A74 for process 95
*Apr 28 21:14:53.983: TFTP: read request from host 10.10.10.22(2993) via Vlan10
*Apr 28 21:14:53.983: TFTP: Looking for Ringlist.xml
*Apr 28 21:14:53.983: TFTP: Sending error 1 No such file
Adding, the old logo remain in the IP Phone flash.
Help...help...
05-02-2011 01:38 PM
Hi Guys
Any idea?
I´m waiting for any help, please...
05-02-2011 02:19 PM
make the tftp alias for the file above, not gkdefault.cfg
Alos , image ID must match in bmp2logo, and config file.
05-03-2011 11:49 AM
Hi Paolo
I just change the alias to:
Please see the debug
CME#
*May 3 18:53:08.555: TFTP: Server request for port 3278, socket_id 0x87FE01AC for process 95
*May 3 18:53:08.555: TFTP: read request from host 10.10.10.22(3278) via Vlan10
*May 3 18:53:08.555: TFTP: Looking for SEP001B0C964AA9.cnf.xml
*May 3 18:53:09.291: TFTP: Opened system:/its/vrf1/XMLDefault7912.cnf.xml, fd 10, size 964 for process 95
*May 3 18:53:09.291: TFTP: Sending block 1 (retry 0), socket_id 0x87FE01AC
*May 3 18:53:09.299: TFTP: Received ACK for block 1, socket_id 0x87FE01AC
*May 3 18:53:09.299: TFTP: Sending block 2 (retry 0), socket_id 0x87FE01AC
*May 3 18:53:09.307: TFTP: Received ACK for block 2, socket_id 0x87FE01AC
*May 3 18:53:09.307: TFTP: Finished system:/its/vrf1/XMLDefault7912.cnf.xml, time 00:00:00 for process 95
*May 3 18:53:09.339: TFTP: Server request for port 3357, socket_id 0x87FE01AC for process 95
*May 3 18:53:09.339: TFTP: read request from host 10.10.10.22(3357) via Vlan10
*May 3 18:53:09.339: TFTP: Looking for United_States/gk
CME#001b0c964aa9
*May 3 18:53:09.375: TFTP: Opened flash:/7912/gkdefault.cfg, fd 10, size 33 for process 95
*May 3 18:53:09.375: TFTP: Sending block 1 (retry 0), socket_id 0x87FE01AC
*May 3 18:53:09.387: TFTP: Received ACK for block 1, socket_id 0x87FE01AC
*May 3 18:53:09.387: TFTP: Finished flash:/7912/gkdefault.cfg, time 00:00:00 for process 95
*May 3 18:53:09.399: %IPPHONE-6-REG_ALARM: Name=SEP001B0C964AA9 Load=CP7912060100SCCP051208A Last=Initialized
*May 3 18:53:09.507: %IPPHONE-6-REGISTER: ephone-1:SEP001B0C964AA9 IP:10.10.10.22 Socket:1 DeviceType:Phone has registered.
CME#
*May 3 18:53:10.667: TFTP: Server request for port 3488, socket_id 0x87FE07E8 for process 95
*May 3 18:53:10.667: TFTP: read request from host 10.10.10.22(3488) via Vlan10
*May 3 18:53:10.667: TFTP: Looking for Ringlist.xml
*May 3 18:53:10.667: TFTP: Sending error 1 No such file
CME#
This is the bmp command:
bmp2logo.exe 10 cisco.bmp cisco.logo
This is the cfg file: (save as gkdefault.txt)
#txt
The command:
cfgfmt.exe -cfgfmt gkdefault.txt gkdefault.cfg
They are the flash files:
157 33 May 3 2011 18:44:48 +00:00 7912/gkdefault.cfg
158 308 May 3 2011 18:45:02 +00:00 7912/cisco.logo
They are the tftp files:
ftp-server flash:/7912/gkdefault.cfg alias United_States/gk001b0c964aa9
tftp-server flash:7912/cisco.logo alias United_States/cisco.logo
The logo in the IP Phone flash still remain.
Please, I need help , my client is getting nervous.
05-04-2011 02:40 PM
Hi guys
Has anyone changed the logo of a 7912, sucessfully?
Please, really I need help!!!....
05-17-2011 06:42 AM
Who has made a Logo change for a 7912 before?
I´m still unable to change the logo.
Pls. I need help,
