Unable to configure voice-service dsp-reservation on cisco 2911
RAJA RAHMAN
Hello Experts
Unable to configure voice-service dsp-reservation under voice-card 0
i am not able to see the option at all
 HQ-Router(config-voicecard)#?
Voice-card configuration commands:
  codec         Manage codec configuration parameters for voice card
  default       Set a command to its defaults
  dsp           Manage DSP configuration for the voice card
  dspfarm       Enable dspFarm feature for this voice card (command will be deprecated in future releases, use the new command 'dsp
                tdm pooling')
  exit          Exit from voice card configuration mode
  local-bypass  Enable TDM hairpinning
  no            Negate a command or set its defaults
ios version c2900-universalk9-mz.SPA.151-2.T.bin"
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16          , VID: V01 , SN: FOC19107FR2
and more over  i have pvdm 3-16 on this router and using only 4 channels of the pri . will i will be able to configure 1 video conference with 2 party .
RR
10 Replies 10
Wilson Samuel
Level 7
Level 7
Could you please share the following:
1. Show inventory
2. sh sccp
I guess you have only PVDM-3 16 and all have been used already.
Hello
Please find the below
HQ-Router#sh sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0.102
        IPv4 Address: 142.102.64.254
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 142.100.64.11, Port Number: 2000
                Priority: 2, Version: 7.0, Identifier: 2
Call Manager: 142.100.64.12, Port Number: 2000
                Priority: 1, Version: 7.0, Identifier: 1
SCCP application services(dspfarm profiles) are not enabled
or haven't associated to SCCP CCM group
HQ-Router#sh sccp
        Port Number: 2000
IP Precedence: 5
I have just used inly 4 channel of the pri  as configured below
controller T1 0/0/0
 shutdown
 cablelength long 0db
controller T1 0/0/1
 pri-group timeslots 1-4,24 service mgcp
Please advise
regards
Raja
Strange..
Could you please show us the Lic type on the router? It may be on IP Basic and not enabled for the Unified Communications.
Technology Package License Information for Module:'c2900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      None          None          None
uc            uck9          Evaluation    uck9
data          None          None          None
Index 1 Feature: ipbasek9
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: securityk9
        Period left: 8  weeks 4  days
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
Index 3 Feature: uck9
        Period left: 8  weeks 3  days
        License Priority: Low
Please help
RR
I think you may need more than 1 PVDM-3-16, as per the following document you cannot share the Cores between Voice and Video (i.e. fragmented cores).
Here is the excerpt:
There are some limitations for the allocation of PVDM3 for IPSLA VO that the user needs to be aware of. PVDM3 is reserved on the router using the IOS® command below:
voice-card 0
voice-service dsp-reservation <percentage>
#The above is for voice while the remaining DSP resources will be used for Video
IPSLA VO presently cannot use fragmented cores. A fragmented core is one that is allocated for both voice and video. This needs to be taken into consideration when procuring/provisioning PVDM3.
Also, here is a thread describing a similar incident
https://supportforums.cisco.com/discussion/11650346/cannot-create-video-conference-bridge-2921
can i mix pvdm 3-16  for video and  pvdm 2-64 for voice activity
Please can you advise .
Hello All
I have  added another pvdm 3-16 but still i am not able to configure
video homogeneous
NAME: "CISCO2911/K9 chassis", DESCR: "CISCO2911/K9 chassis"
PID: CISCO2911/K9      , VID: V01 , SN: FCZ143173FC
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1  , VID: V01 , SN: FOC10501AK8
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16          , VID: V01 , SN: FOC18461QV9
NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply"
PID: PWR-2911-AC       , VID: V01 , SN: AZS134605NS
dsp 1:
State: UP, firmware: 26.8.0
Max signal/voice channel: 16/16
Max credits: 240
num_of_sig_chnls_allocated: 11
Transcoding channels allocated: 4
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 144, reserved credits: 0
Signaling channels allocated: 4
Voice channels allocated: 0
Credits used (rounded-up): 0
Group: FLEX_GROUP_XCODE, complexity: HIGH
Shared credits: 0, reserved credits: 96
Transcoding channels allocated: 0
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
dsp 7:
Max credits: 240
num_of_sig_chnls_allocated: 0
Shared credits: 240, reserved credits: 0
Signaling channels allocated: 0
Slot: 0
Device idx: 0
please help
regards
raja
Hi RR,
Could you also share the "sh run" and " sh inv" for exact calculation. PVDM3-16 should not be enough for configuring video conference even only 4 PRI channels are consumed as per DSP calculator.
Rajan
Hello Rajan
Please find the attached
and advise shall i mix pvdm 2 and 3 on the same router
Please advise
regards
raja
aysar3000
Dear
you cant have video conference with PVDM 3-16
you should have PVDM3-128 or Above
