Unable to dial 3 digit code 195 ( on CME )
rstevenson1
Right then, this issue has been trailing on for a long time now and the finger of blame has been going back and forth between ourselves and the Telco provider.
Our customer is setup with CME and has 4 ISDN BRI connections to the router, they can dial through to any internal/external numbers no problems, apart from this 195 number (which is a directory inquiries number for the blind)
Whenever this number is dialled, the response in the Q931 debugging is as follows..
Jul 25 11:17:12.546: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 300
Jul 25 11:17:12.546: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 195
Jul 25 11:17:12.546: ISDN BR0/2/0 Q931: TX -> SETUP pd = 8 callref = 0x3F
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x8A
Exclusive, B2
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0080, '300'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '195'
Sending Complete
Jul 25 11:17:12.722: ISDN BR0/2/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xBF
Channel ID i = 0x8A
Exclusive, B2
Jul 25 11:17:14.086: ISDN BR0/2/0 Q931: RX <- DISCONNECT pd = 8 callref = 0xBF
Cause i = 0x829C - Invalid number format (incomplete number)
Progress Ind i = 0x8288 - In-band info or appropriate now available
I've altered the plan & types of the dialled number to no avail.
The Telco provider advises they can dial this 195 number straight from the ISDN termination equipment no problem.
We currently have the following dial-peer configured to match this number ( before investigating it was set just to match any 3 digit number)
dial-peer voice 31 pots
trunkgroup ISDN-BRI
corlist outgoing CLASS-DIR
destination-pattern 9195
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
forward-digits all
The user would dial 9195, the leading 9 would the be stripped by the outbound translation-profile applied to the trunk group, then forwarded onto the Telco line as just 195 ( which they expect to receive)
Help :<
27 Replies 27
paolo bevilacqua
You are sending the number correctly. The only thing that can possibly be "wrong" on your side, is that telco expects a different calling plan/type IE for this call, eg ISDN/national. Try configuring like that in the translation-profile, or ask telco about how do they want these parameters to be set.
If they can dial successfully with an ISDN phone connected to the same BRI as the router, you should be able to see that as well with debug.
Unfortunately I've tried every available option for the type of call i.e National/International/network/reserved5 etc etc whilst keeping the call plan as ISDN.
Tried to get such information from the Telco, but all I get is strange looks.
Unsure what you mean about being able to see them making a test call to this number from the ISDN2e (termination equipment) box, as obviously they're connected straight to their lines and not our router.
I've had a little difficulty with my forward-digits-all commands, try just using forward-digits 3, see if that helps. Does your 999/911 emergency call work?
Calling 3 digit numbers does work Ok, the user has called through to 150 (number for main Telco in Britain) which rings out and picks up the other end perfectly fine.
So it doesn't appear to be a problem with us sending out 3 digit numbers.
Ive just slung in :
dial-peer voice 5 pots
port 0/1/0
forward-digits 3
no sip-register
And got through to the lovley directory lady the other side. Have you tried removing all your group settings and cor list settings; just have a plain old dial peer without any of the trimmings to eliminate anything interfering with the call setup
davieshuw,
How do you have the plan/type setup for this call? did it go through as unknown/unknown or?
Just tried with this basic config and came up with the same invalid number format error again.But I hand't altered the plan/type, so it went through as unknown/unknown
I did a debug when i call 195 (via unknown/unknown) and it was successful. Is it something stupid like the call is being shoved out of the wrong port possibly?
Well, theoritically there isn't a wrong port it can go out on.
But I had basically copied your dial-peer for this number, so therefore it was pushed out of bri0/2/0, which I have now tested with unknown/unknown and ISDN/National and still doesnt work.
Regardless of the actual dial-peer, I am also making Isdn test calls from the CLI ( sourcing from a specified interface) and still shows the same results, invalid number format...
What I mean, can you ask them to come onsite and using a phone of their own, call 195 from you line.
Due the way ISDN BRI works, you *should* be able to see their call with debug ISDN Q931, even it the router is not involved at all in the call.
This should be easy to setup because normally NT1 equipment has two RJ45 connectors.
Note: in the trace you sent, type plan is unknown/unknown, not ISDN.
Be aware that if BT CAN make that call, they'll charge you ?100 plus VAT for the privilege.. As they did when they came out to check my compand error :(
andrew.shore
OK this may be a silly question, Im only asking coz i had a similar issue with AOL a few years ago.
Are you sending BT the correct CLI? Or are you hiding your CLI? I believe 192 is a subscriber service and if BT can't see who to bill then they may reject the call?
Andy
That is a very reasonable suggestion that I didn't think about. 300 is clearly not a valid CLI.
The CLI comes through fine, not as 300, but the full code. But regardless of this, the number - 195 does not need registration, so there would not be an issue with the sourced dialling number.
anderson-david
Level 3
Level 3
use this debug and see where it points ie it will tell you if its using the wrong dial peer etc
debug voip ccapi inout
Also could you post your config
I hope this helps
Dave
