Unable to send FAX using ATA 187
acharyr123
Level 3
Level 3
I have ATA 187 running with CUCM 7.1.5....I can receive FAX without any issue, but unable to send FAX at all....Why that so?? Is that a bug with ATA 187?? Can someone guide me...
abukuru95
Level 3
Level 3
Hi, did you check on the CSS for the fax DN number ?
it may be restrictions for placing calls. if not sure with the CSS, use the none CSS and test.
do not forget to rate if this helps!!
atrin.saghebfar
can you call form ATA?
if its possible , dial the fax number which you want to send fax nad hear the fax tone, is it ok? and can you listen to handshake tone?
It's working fine..
Rgds,
Partha
Mobile: +971503507853
