Unable to transfer call coming from PSTN
techguy
Level 4
Level 4
I have h323 voice gateway cisco 2611XM with NM-2V card (means VIC-2FXS and VIC-2FXO). Its connected with CUCM 7.1. Internal extension can transfer the calls but calls coming PSTN cant tranfer the calls to internal extension. Its disconnecting immeditely.
Is there any codec problem or do i need any dsp resourse ?.
12 Replies 12
acampbell
Can you test if this same IP phone can put external callers ON HOLD for say 5 seconds then RESUME.
If this does not work then the issue is MTP related.
When a Xfer is set up it uses HOLD.
Let us know the results.
Alex
Regards, Alex. Please rate useful posts.
i did what you said. I can hold the call from that phone set then i did unhold. It works i mean to say call wasnt disconnected.
Thank you for the update.
This then means the issue looks to be CODEC related.
Can we see the config from your gateway.
Alex
hostname XXXXXX
boot-start-marker
boot system flash
boot-end-marker
enable secret 5 XXXXXXXX
no aaa new-model
clock timezone PCTime 4
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
trunk group  FXO
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
sip
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
application
  global
  service alternate DEFAULT
interface Loopback105
ip address 10.1.209.193 255.255.255.192
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.1.209.193
ip http server
no ip http secure-server
voice-port 1/0/0
description FXS port
signal groundStart
echo-cancel coverage 32
bearer-cap Speech
caller-id enable
voice-port 1/0/1
signal groundStart
voice-port 1/1/0
description FXO port
trunk-group FXO
input gain -3
output attenuation -1
no comfort-noise
timing hookflash-out 50
connection plar opx 2700
impedance 900c
music-threshold -45
bearer-cap Speech
voice-port 1/1/1
trunk-group FXO
input gain -3
no comfort-noise
impedance 900c
music-threshold -45
bearer-cap Speech
sccp local Loopback105
sccp ccm 10.50.2.3 identifier 1 version 4.1
sccp ccm 10.50.2.4 identifier 2 version 4.1
sccp
sccp ccm group 1
associate ccm 2 priority 2
associate ccm 1 priority 1
associate profile 3 register ABUDHABI_MTP
associate profile 2 register ABUDHABI_XCODE
associate profile 1 register ABUDHABI_CONF
dspfarm profile 2 transcode
associate application SCCP
shutdown
dspfarm profile 1 conference
shutdown
dspfarm profile 3 mtp
codec g711ulaw
maximum sessions software 10
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 2 pots
trunkgroup FXO
tone ringback alert-no-PI
description Mobile
destination-pattern 905........$
fax rate disable
prefix 05
dial-peer voice 3 pots
description National
destination-pattern 90[234678].......$
fax rate disable
port 1/1/0
prefix 0
dial-peer voice 4 pots
description Emergency
destination-pattern 9[19]..$
fax rate disable
port 1/1/0
forward-digits 3
dial-peer voice 7000 voip
preference 1
destination-pattern 99..
voice-class codec 1
voice-class h323 1
session target ipv4:10.50.2.3
dtmf-relay h245-alphanumeric
req-qos guaranteed-delay audio
acc-qos guaranteed-delay audio
fax-relay ecm disable
fax rate 14400
fax nsf 000000
fax protocol pass-through g711ulaw
no vad
dial-peer voice 7001 voip
preference 2
destination-pattern 270.
voice-class codec 1
voice-class h323 1
fax rate 14400
fax nsf 000000
no vad
dial-peer voice 10 pots
trunkgroup FXO
description International
destination-pattern 900.T
fax rate disable
prefix 00
dial-peer voice 301 voip
description CUE
destination-pattern 9913
session protocol sipv2
session target ipv4:10.1.209.62
dtmf-relay sip-notify
codec g711ulaw
no vad
telephony-service
max-ephones 10
max-dn 10
ip source-address 10.1.209.193 port 2000
time-zone 21
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
transfer-system full-consult
line con 0
exec-timeout 0 0
speed 115200
line aux 0
line vty 0
password XXXXXX
login
line vty 1 4
password XXXXXX
login
scheduler max-task-time 5000
scheduler allocate 4000 1000
ntp clock-period 17210598
ntp server 192.117.105.69
ntp server 219.87.217.84
ntp server 152.118.24.8
ntp server 163.25.109.16
end
I see that the H323 Ip address is 10.1.209.193
Can all the phones see this address.
Also I see your codec class is this order
voice class codec 1
but your MTP is:-
codec g711ulaw
I would change the CODEC class to be :-
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
Alex
I changed the codec order but it did not work...
What about IP connectivity from the gateway on Ip address 10.1.209.193 to all the phones
Alex
IP Phones can ping 10.1.209.193. This ip address is loopback address.
Let me tell you something that operator can transfer on the extensions which are not in that office. (does not matter that on which route partition they are.) Does it seem routing problem ?
jbankstonfla
I just fixed a nearly identical problem in my lab.
FXO 1/0/0 - pstn line 1
FXO 1/0/1 - pstn line 2
FXS 1/1/0 - fax
FXS 1/1/1 - analog phone
my problem was that without a dsp farm resources, all inbound calls were forcing G.729. I went under my voip peer of the H.323 gateway and forced G.711 inbound to CUCM. I also found a code issue when I try to forward a call to the analog phone, both fax and analog phone are trying to answer. When I disconnected the fax, the analog phone works perfectly, so my issue has to do the FXS ports in a NM-2V in an H.323 2610XM router.
After forcing G.711, everything cleared up including access to Unity for voicemail, inbound calls from pstn conf to IP phones, etc. all of it.
Keep in mind that I don't have a dsp farm, just using the media resources from CUCM.
-Jeff
i am not not using FXS port for any purpose. I am using only IP Phones which are registered on CUCM. When a calls comes gateway (via FXO port) where i have connection plar of reception extension which is registered on cucm. It goes through VoIP dial -peer.
Anyways when calls comes direct to reception extension then he cant transfer that line to any user.
I see your router is an old 2611
Have you checked for IOS bugs
May be you need to upgrade
Show version in posting.
Alex
This worked for us, after forcing g.711 everything worked nicely. Thank you !
