Unity Connection 7 - Media Master Access denied error
davidme
Running UC7 and when trying to record a new call handler via the Media Master through a phone handset - I get the following error message:
Server Error:
The server 192.168.10.10 reports the following:
Code 23
Description: Access Denied
Anyone else seen this or know how to get round it? I can record the messge via Sound recorder for the time being but I'd like to get this working.
Dave
7 Replies 7
guy.richard
Have the VoiceMail ports been set with a CallingSearchSpace able to reach the phone ?
Hope that help
Guy
Hi Guy,
Yes - All voicemail is working fine with this exception. Outgoing calls are enabled too.
Cheers
Dave
Dave,
I am hitting the same issue. Since I see no more messages I am assuming you were able to figure this one out.
What was the resolution?
Charlie
Hi Charlie,
This one was never resolved. The customer is recording files externally and uploading the wav files currently. Good luck with finding the resolution - would love to know what is causing it!
Dave
Hi Dave/Charlie,
There are some good tips in this doc, many times this problem is due to a lack of TRAP Ports;
Setting Up Playback and Recording Devices for the Media Master
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/user_setup/guide/7xcucus020.html
Hope this helps!
Rob
Thanks Rob,
I do have the default TRAP checked and all my ports are setup for TRAP. I have opened a TAC Case on this, we'll see what they come back with.
Charlie
Guys,
Today it is working in IE7. Yesterday it was not working. My theory is that after installing jre-6u7-windows-i586-p.exe, I did not restart my pc until today. That is the only change I made on my pc that could have any relevance. Still does not work in FireFox. Hopefully this will work for you.
Charlie
