Unity Connection 8.0 Install with 8.5 as a patch
alexjrcnp
I'm trying to find out if Unity Conn 8.5 update will install successfully as a patch on a new install. Install DVD is 8.0
I tried in a lab environment and it failed.
Thanks in advance.
Rob Huffman
Hi Alex,
I think you are hitting this bug;
CSCtn61453            Bug Details
Applying 8.5.1 software as patch results in corrupted CUC installation.
Symptom:
After fresh installation of 8.5.1 software, we can notice several problem symptoms.
- Connection services and Connection DB does not start
- System cannot be accessed via web page
- Informix error messages for certain CLI commands
Example :- show cuc cluster status
com.informix.asf.IfxASFException: Attempt to connect to database server (ciscounity) failed.
Command failed
Conditions:
It is observed during fresh installation of Unity Connection product when installation was
started with earlier version of software and 8.5.1 software was applied as a patch during the setup process.
Workaround:
First, perform a fresh installation of earlier version of software using the install media. Then after verifying the installation, proceed with the upgrade to 8.5.1 as a separate process.
StatusStatus
Open
Severity Severity
2 - severe
Last Modified Last Modified
In Last 3 Days
Product Product
Cisco Unity Connection
Technology Technology
1st Found-In 1st Found-in
8.5(1)ES1
Cheers!
Rob
5 Replies 5
Roman Rodichev
Level 7
Level 7
Haven't tried that yet.
One thing for sure is you'll need a 8.5 license.
CM 8>8.5 and CUPS 8>8.5 - no license requires
CUCx 8>8.5 and UCCX 8>8.5 - license required
Rob Huffman
Hi Alex,
Symptom:
Command failed
Conditions:
Workaround:
StatusStatus
Open
Severity Severity
2 - severe
In Last 3 Days
Product Product
8.5(1)ES1
Cheers!
Rob
Would there be a workaround for the 2nd node though?
Publisher is at 8.5.1. Subscriber will not join cluster unless is at 8.5.1
I definitely think this bug is the problem.
Alex
Rob Huffman
Hi Alex,
I believe that the only time CUCM will allow mismatched versions is during the upgrade
process. Being that this is a lab envirnment, I would try installing 8.0 on the Sub, let it finish
and then upgrade to 8.5
Cheers!
Rob
I got a hold of an 8.5 dvd, that solved my problems.
The problem was that how do you finish installing CUC 8.0 unless it's the first node. The second node has to talk to first node. The first node is at 8.5.
Can you tell it is the first node in order to finish install, upgrade, then make it part of the cluster?
Alex
