Unity Connection 8.5.1 not deleting deleted messages
billfreitas
I am running CUC Version 8.5.1ES16.11900-16. My users mailboxes are now filling up because Unity Connection has stopped deleting deleted messages. I have check and changed the Message Aging Policy to permanently deleting messages in the deleted Items folder to 1 day and still having the issue.I have confirmed the issue by leaving then deleting a message to myself and it has been a week and it still is there.
Does anyone have any ideas on what I could check or further troubleshooting I could do.
Bill
7 Replies 7
Roman Rodichev
Level 7
Level 7
Stupid question. Is the appropriate Message Aging Policy selected under User's Mailbox settings?
clileikis
Level 7
Level 7
Also have you rebooted your CUC server(s). We've seen the same issue resolved after a reboot.
All users have the default policy and I modified that policy. I even tried to create a new policy and applied it to my mailbox with the same result.
I have not tried rebooting, I can try that. May I ask what version you had the issue on?
I believe it was also on 8.5.
We have just started experiencing this same problem, Unity Connection version 8.5.1ES47.12900-47.  Wondering if the reboot worked and/or what resolved the issue?
Hi Cheryl,
Just wondering if you had seen this bug? It looks like 95 TAC cases related to this
issue;
CSCtr43597 - UC 8.5 / 8.6.1 Message Aging Does Not Work
Description
Symptom:
UC 8.5 / 8.6.1 message aging policy set to purge deleted messages after one day
and it does not purge messages.
Conditions:
The root cause is known:
If the difference between the MessageModificationtime+DeleteAgingRuleNumDay and
the SystemCurrentTime is more than 99 days,  the exception" Overflow occurred
on a datetime or interval operation"  is thrown by Informix as part of SELECT
query on VIEW vw_MessageAging.
And the MessageAging procedure is aborted.
Workaround:
Contact Cisco TAC for workaround
Details
First Found in:                          (1)
8.5
Status:
Fixed
Last Modified:
May 29,2013
Fixed in:                          (7)
8.6(2.10000.30),8.6(1.98000.53),8.6(1.98000.126)
8.6(1.64),8.5(1.13031.1),8.5(1)ES56,1.0(0.98000.42)
Product:
Cisco Unity Connection
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
"go easy...step lightly...stay free "
- The Clash
Thanks Rob -
I've been searching for anything related to this. We've been on this version for almost 2 years.The problem only started in the last few month's - and it doesn't seem to affect all users, which has made it difficult to isolate. I have tried everything that's been mentioned, yet still have the issue periodically.
I'll contact TAC - Thanks so much.
