04-05-2013 08:07 AM - edited 03-16-2019 04:38 PM
Hi Expert/Masters,
I am trying to upgrade unity connection form 8.5 to 9.1 it keep failing.
I installed refresh upgrade COP file and regular upgrade process and it keep failing.
Please assist me where i am going wrong so i that can make it to 9.1 version.
I am attaching VM hardware summary and upgrade error.
Thank you and I apprecaite that.
Solved! Go to Solution.
04-05-2013 07:21 PM
Hi Sham,
I have checked the snapshots .In above snapshot,1vCPU is there while in the bottom one , it is showing 2 vCPU.
For Unity Connection VM one CPU core must be idle/unused (it is actually being used by ESXi scheduler).
Please refer the URL for Sizing:
http://docwiki.cisco.com/wiki/Sizing_Guidelines
This could be one of the cause.
regds,
aman
04-05-2013 08:15 AM
Hi Sham,
What is the detailed current version of UCxN and the COP file u are using?
regds,
aman
04-05-2013 08:20 AM
Aman,
Here are the version details and COP file details..
Untiy Connection version:
Cisco Unity Connection version: 8.5.1ES65.13900-65
COP file:
ciscocm.refresh_upgrade_v1.1.cop.sgn
When i installed COP file i was successful.
Upgrade IOS image file:
UCSInstall_UCOS_UNRST_9.1.1.20000-5.sgn
04-05-2013 08:17 AM
Hi Shamkumar,
It appears you're upgrade file is the unrestricted version, more than likely you need the restricted version.
HTH,
Chris
04-05-2013 12:21 PM
04-05-2013 08:36 AM
Hi there,
The error shown in the first attachment may be the cause;
Error encountered:This server is not supported for use with the version of Unity Connection
you are trying to install
You'll need to check the specs here;
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/supported_platforms/9xcucspl.html
Cheers!
Rob
"Hours are like diamonds, don't let them waste
Time waits for no one, no favors has he"
- Stones
04-05-2013 08:45 AM
Hi Sham,
I agree with Mr. Rob since the snapshots which u have pasted do not show anyhting related to RST/UNRST version.It points to server incompatibility.
can u share output of show version active from CLI of UCxN or first page of Unity connection from GUI?
For RST version : UCSInstall_UCOS_8.5.1.13900-5.sgn.iso
For UNRST version: UCSInstall_UCOS_UNRST_8.5.1.13900-5.sgn.iso
regds,
aman
04-05-2013 11:56 AM
Hi Aman,
Version details
admin:show version active
Active Master Version: 8.5.1.13900-5
Active Version Installed Software Options:
Thank you.
04-05-2013 12:07 PM
Hi Rob,
I compared existing vm hardware which i am trying to upgrade to 9.1 by deploying new ovi template of 9.1 version from Cisco..I dont see any hardware compatibility issue coz i have more resources than min requirement for version 9.1 so i guess hardware is not the issue but as per server it says server not supported.
For your reference I am attaching both template i.e. 8.5 upgrading to 9.1 and ovi from cisco 9.1 vm resource summary
Please compare and assist me please.Thank you.
04-05-2013 07:21 PM
Hi Sham,
regds,
aman
04-08-2013 08:10 AM
Aman,
Thank you so much Aman..I changed from 2CPU to 1CPU and upgrade was successful with no issues.I really appreciate your assitance.
I also apprecaite all other members replies and time too.Thank you so much.
Aman I have a question for you do you Prateek Reddy? who worked for HCL on the DC and IPT project.
04-08-2013 08:19 AM
Hi Sham,
Gr8 ... Your problem was resolved...
I am not aware.May be he is in Global Operations...
regds,
aman
04-08-2013 10:05 AM
May be..Thanks though.
