unity connection voicemail delete from Cisco PCA
Abhishek Singh
Hi We have a user, who isnt able to delete the voicemail from his cisco phone.
He has provided me the timestamp for the same.
I decided to use Cisco PCA , so when i try to go the end user on cisco unity connection and go this >> user basics>> password, settings, choose password >> i am not able to see a web application password download option.
cisco unity connection version is : 6.1.2 and we specifically need to delete a voicemail message ( solitary).
Appreciate some suggestion on this.
Whatever level you reach getting better never stops -- Sachin Tendulkar
5 Replies 5
Rob Huffman
Hi Abhishek,
Hope all is well my friend
Does the users COS have the licensed feature "access to Inbox"?
Licensed Features
Cheers!
Rob
"Why not help one another on the way" - Bob Marley
Hi Rob,
Trying to lead an ideal life and learn .
How are you?
I tried checking the COS page and these options were not checked, since this is for a specific user ( not users), i hope this is not going to effect the other configurations adveresly ( which does not happen ideally), but i need your kind confirmation on this, as i am someone who does not make all the UC solutions decisions here, and have to get approval from other guys.
garethpeart
Level 3
Level 3
Also, if you are authenticating through LDAP, you won't see the web app password (controlled by LDAP)
Gareth
Hi Gareth,
Thanks for this important part of information.
Rob Huffman
Hi Abhishek,
Life is good my friend
Changes to the COS will effect all user's on that specific COS so
you may want to create a new COS with Inbox access and move
that user over at least temporarily. Check your licenses and see what's
available for;
Cisco Unity Inbox users
Cheers!
Rob
