06-04-2014 10:28 AM - last edited on 03-25-2019 08:29 PM by ciscomoderator
I'm working on a 2911, with a ISM-SRE-300-K9 running CUE 8.6.7 (confirmed clean install). The CTI Ports are not registering with CUCM, all the steps have been triple checked, yet they don't register.
The CUE talks to CM fine and pulls the 4 CTI Ports we configured on CUCM, but if you click the 'show available ports in CUCM" it immediately crashes the CUE and it reboots.
I have a case open and it may be a bug, but wanted to see if anyone here has CUE working with CUCM 10.
Thanks-
06-04-2014 11:48 AM
I assume you have triple checked this as well in CLI?
1. Jtapi Integration to CUCM
ccn subsystem jtapi
ctiport xxxx xxxx xxxx xxxx
ccm-manager address x.x.x.x x.x.x.x
end subsystem
2. JTAPI config Pilot number config
ccn trigger jtapi phonenumber XXXX
application "voicemail"
enabled
maxsessions 8
end trigger
06-04-2014 12:04 PM
Yes, confirmed that is all correct.
The ports don't register and when you click "expand to also show available ports on cucm" the CUE crashes:
CRASH appsServices startup startup.sh System has crashed. The trace buffer information is stored in the file "atrace_save.log". You can upload the file using "copy log" command
if I enable jtapi debugs, it just says out of service:
1936: Jun 03 14:38:03.212 EDT %JTAPI-MISC-7-UNK:(P42-x.x.x.x) ReceiveThread starting up...
1937: Jun 03 14:38:03.213 EDT %JTAPI-PROTOCOL-7-UNK:(P42-x.x.x.x) received Response: com.cisco.cti.protocol.FailureResponse {
sequenceNumber = 0
result = -1932787395
description = Provider Init is not done -- Open rejected
1938: Jun 03 14:38:03.214 EDT %JTAPI-PROTOCOL-7-UNK:(P42-x.x.x.x) received Event: com.cisco.cti.protocol.ProviderOutOfServiceEvent {
eventSequence = 41
PROVIDER_OUT_OF_SERVICE_EVENT = 200
06-04-2014 12:11 PM
This might be a silly question but you have created the CTI ports manually under devices --> phones with the correct DP, Location, PArtition, CSS and MRGL? And you have restarted the CTI Manager under serviceability?
06-04-2014 12:14 PM
All done as well, pretty sure this is going to be a bug but was hoping someone else here has gotten cue and cucm 10 working together.
06-04-2014 12:16 PM
All the best I am only doing CUCM 10 and CUE next month when I have some spare time in the LAB, but will keep an eye here. All the best hope you get it going.
06-04-2014 12:26 PM
I will definitely post the resolution if found outside of this thread. The TAC engineer found 2 similar cases and was tracking down the owners of those cases to get a status.
06-13-2014 02:12 AM
I'm having the same problem with CUCM 9.1.2.11900-2.
The CTI Ports don't register on CUCM and when I press the 'Expand to also show available ports on CUCM' the CUE crashes and reloads.
Is there already a solution for this issue?
Thanks.
07-30-2014 02:34 AM
Hi Kevin,
Did TAC respond you for the same problem ?
Our client is going to upgrade cucm from 8.6 to 10.5 & having same CUE version in 2951.
07-30-2014 02:52 AM
Cisco have released a bug ID but it is listed as "fixed" with a workaround of downgrading cucm..
https://tools.cisco.com/bugsearch/bug/CSCup55019
07-30-2014 05:39 AM
Correct - pretty rough fix. I would open a new tac case and see if there is any unofficial workaround yet or ES release.
We ended up putting in a CUE on UCS-E with CME as SRST for this remote site and haven't had another client yet with a CUE go to 10.
08-13-2014 03:14 PM
Hi Kevin,
Did you find any unofficial workaround from TAC ?
Would you mind if you can share solution ?
Becasue I have an upgrade about to come soon from cucm 8.6 to cucm 10 with SRST routers having AIM & NM CUE modules.
Would appreciate your feedback.
Conie
08-13-2014 07:16 PM
No, it doesn't look like there has been a resolution yet for the bug (CSCup55019). In this design we went with a UCS-E module in the router and ran unity connection and cme-as-srst
08-15-2014 05:06 AM
Thank for update.
I am not able to find out about UCS-E module.
Which module is this ? How did you use it for Unity Express ? Do you have details about it ?
I believe UCS-E its UCS server not module.
08-15-2014 05:22 AM
Correct, UCS-E is a UCS Server blade for routers. The customer had full blown CUCM/Unity Connection at the other sites so we had returned the unity express router for a 2911 UCS-E 140S and install full blow Unity Connection on it with cme-as-srst on the router so Unity connection will register locally if the wan goes down.
