unity on vmware
youssef.erraki
please a try to install unity connection on Vmware version 8 but the wizard installation just shows me cucm install but when i put the CD on physical server it  appears
regards
6 Replies 6
Hello, maybe you.re using wrong OVA files, use the correct files for CUC.
Vmware version 8? I think that the vmware version sopported for the hardware it's version 5.
Chris Deren
That means you deployed incorrect OVA template and hardware settings dont match and hardware detection gives you no option for Unity.
Chris
I uplaod
CUC_5000_user_v1.0_vmv7.ova version and i put DVD of CUC 9.1 but it deosn't appear just CUCM and it shows me down unsopported install
best regards
can you please Some one provide me with URL of valide ova version 9.1 OR 8.5 that i can used to install a CUC on Vmware v8
Best Regard
