Unity password voice mail
Hello Friends,
I have Unity Server and i need change password for several users. How can i do it?  Can i connect at server and do it through web explorer or console?  How can i do it in both alternative?
Thanks for your help...
5 Replies 5
Chris Deren
Sure, login to admin page, locate the subscriber and change the password under password settings.
HTH,
Chris
Suscriber Unity?  Can i do it into Publisher Unity?
I wanna change several password users Chris...
A subscriber is a user on Unity, I take it you don't have Unity but Unity Connection instead, in either way you can login to either Subscriber or Publisher to make the change, typically you want to do it on the Pub.
HTH,
Chris
arunkum3
Hi Claudio,
The Bulk Edit Utility allows you to change many users passwords at one shot
For Unity Connection, this link should answer your question.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/user_mac/guide/8xcucmac090.html#wp1049549
For Unity please refer this link:
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a0080a59413.shtml
HTH,
Arun Kumar
CCIE (Voice), Cisco Systems
Hello Arunkum3.
I forgot my voice-mail password. How can i get a new voice-mail password or change it? I´m working with a Cisco Unity Server.
