11-09-2011 09:53 AM - edited 03-16-2019 07:57 AM
I have several of these phones and the **# unlock config code does not work on them. There was another unlock config that I believe was 4 digits to unlock the phone. Can anyone help before they end up in the trash unnecessarily?
01-06-2012 04:21 AM
Try a factory reset.
01-06-2012 07:36 AM
If they are running a SIP firmware, **# will not work.
Press the settings key, then scroll down and see if there is an option "9 unlock config".
If you do not know the password, try cisco.
03-21-2016 07:58 AM
This solution worked for me.
02-28-2020 09:55 AM
It's 2020 and still found this post useful. Have a 7940 that has a SIP load on it for some reason. Could not figure out how to unlock it to modify the settings. The info provided here worked!
Cheers!
01-06-2012 07:41 AM
Also, if this is CUCM 4+ you need to first press Settings before doing **#
HTH,
Chris
03-01-2016 06:39 AM
try the deault "cisco"
03-30-2020 02:15 PM
will this work on softphones?
