Unmapped Exception Null when changing BLF Speed Dial
Victor Circelli
We have a CUCM 8.5 running for more than 1 year withtout major issues.
In the last month, the following error occured two times.
When saving changed made on BLF Speed Dial (7900 phones with expansion modules, so, a lot of Speed Dial), it shows an error message that tells "Unmapped Exception Null", and all the Speed Dial configurations (that already exisists) are lost.
Made some research and found this document, that tells the browser version.
It states that IE 6 is supported (we're using IE6).
Did you saw this before?
Rob Huffman
Hi Victor,
It could be this bug perhaps;
CSCtn65309 - BLF Speed Dial Unmapped Exception
Symptom:
Unmapped Exception Null received when editing/saving BLF Speed Dials.
Conditions:
Select any devices BLF Speed Dial extension on the phone configuration page.  Then highlight an
extension, right click with the mouse to Cut it, then right click to paste it into a different field
when being saved we get a "Unmapped Exception null"
Workaround:
Use Control-X and Control-V
Further Problem Description:
All versions of CUCM are affected. I personally tested 6.1.4, 7.1.3, 8.0.3, 8.5.1
Details
First Found in:                          (3)
7.1,8.0,8.5(1)
Status:
Fixed
Last Modified:
Nov 02,2012
Fixed in:                          (22)
9.0(0.95070.39),9.0(0.95070.38),9.0(0.95010.1)
8.6(1.99989.1),8.6(1.99986.1),8.6(1.97011.2)
8.6(1.97011.1),8.6(1.96000.51),8.6(1.96000.1)
8.6(1.95190.40),8.6(1.95050.1),8.6(1.95040.1)
8.6(1.95020.58),8.6(1.95020.1),8.6(1.10001.1)
8.6(1.10000.43),8.6(1.10000.1),8.6(0.99981.2)
8.6(0.98000.50),8.6(0.98000.16),8.6(0.95180.9)
1.0(0.98000.42)
Less
Product:
Cisco Unified Communications Manager (CallManager)
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
"What you don't have you don't need it now"
- U2
5 Replies 5
Rob Huffman
Hi Victor,
Symptom:
Conditions:
Workaround:
Details
First Found in:                          (3)
7.1,8.0,8.5(1)
Status:
Fixed
Last Modified:
Nov 02,2012
Fixed in:                          (22)
1.0(0.98000.42)
Less
Product:
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
- U2
I thought this was a bug but no one can beat the legend in tracking them down!
Hailey,
How does that saying go.........
"Legend in his own mind" ...hahahaha!
Thanks buddy! +5 right back at ya.
Cheers!
Huff
- U2
Thanks Rob!
I searched the Bug Tool Kit for "unmapped" or "exception" but this don't came to me.
Cheers!
Rob Huffman
Hi Victor,
You are most welcome my friend
I've been using the beta Bug Search Tool for most searches
these days and this is where the listed bug was identified;
BST
https://www.cisco.com/cisco/psn/bssprt/bss
Cheers!
Rob
- U2
