Update TFTP Address on IP Communicator
Thiago Gandara
Hi Voice team, i change the CUCM on my company to version 9.1.
I had to change the ip address, the problem is that now I have more than 100 ip communicator, how do I dynamically change the TFTP address that is registered?
Thiago
23 Replies 23
Wao! Thiago not a even a single star for all my troubles!
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Sorry, i forgot...
You help me a lot.
I realized I have some computers that have IP communicator but does not have the option TftpServer1 and TftpServer2 Communicator, I tried to create the registry but did not work.
Hi Thiago.
In that case you should change two registry keys.
Put AlternateTftp key to 1 (the path is the same that i specified above)
and modify TftpServer value as above
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi.
I would also add that only IP Communicator should be resterted  to make valid registry changes both on Win7 and XP.
Carlo
Thanks, i will make the test later.
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Cisco Systems, Inc.\Communicator  is another place to look.
also https://www.browserling.com/tools/hex-to-ip  Hex to IP conversion.
https://www.browserling.com/tools/ip-to-hex  IP to Hex conversion
Rob Huffman
Great work to all involved here (+5) !! An extra +5 for Deji for going above and beyond
to help others here @ CSC
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
..and +5 to you my friend because you have always a good word for everyone here : )
Carlo
