Updating line description for specific site through bulk tool
ulambaday
Hello all,
 I have CUCM 9.1.2, looking for an option to update multiple phones.
Is there an option to update line description(Line Text label) for a specific site through bulk tool??
Jaime Valencia
Yes, but you would need to create the CSV file for this (assuming you want a different value per line), or use BAT query option to set the same setting for a group of phones
java
if this helps, please rate
Jaime,
 Thanks for the reply
I will have to give different value per line. So, create a CSV file for those phones and update it through  import/export or update phones(custome file??
FYI - Those phones are already registered.. will that be an issue?
