Upgrade CCM from 5.1(3) to 7.1
chidd
Dear all !
I have a plan to upgrade CCM form 5.1(3) to 7.1. After checking the compatibility matrix for Software and hardware, I found my CCM can upgrade to 7.1. However, I can not find the Part Number to upgrade from 5.1(3) to 7.1. only form 6.x to 7.x is available.
Can anyone know which is the part-number to upgrade from 5.1 to 7.1 ???
Chidd
nihdas
Can you please send me any doc which says about the compatibility matrix for Software and hardware?
Nihar
Hi Nihar,
This is the "master" list for Server support;
Supported Cisco Unified Communications Manager Releases by Server
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
For more information about supported Cisco Unified CM upgrades, see the Cisco Unified Communications Manager Software Compatibility Matrix at the following URL:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html
Hope this helps!
Rob
Thanks Rob.
chidd
I am still waiting for part number which used to upgarde form 5.1 to 7.1. Can anyone help ???
Chidd
