09-24-2021 01:21 AM - edited 09-24-2021 01:22 AM
Hello All
I have Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.5(3)M7, RELEASE SOFTWARE (fc1) with CME version 10.5. Can I upgrade CME to version 12.X - 14.X?
Solved! Go to Solution.
09-24-2021 01:44 AM
I dont see a CME version mentioned compatible more than 12.0 on IOS. ISR 2900 are getting EOL next year.
To have 12.0+ and 14 I believe you need to upgrade your hardware to isr 4K.
Refer below link for more informations.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/33matrix.html
09-24-2021 11:47 PM - edited 09-25-2021 04:38 AM
There is AFAIK not any separate download for CME alone. It is apart of IOS, so the version of CME that is in the IOS is the version you can get to. For the ISR2 platform I think that the maximum you can get to is 12.0, for anything above this you’d have to do as @Nithin Eluvathingal wrote, aka change out the hardware for an ISR 4K or newer.
09-24-2021 01:44 AM
09-24-2021 02:09 AM
Can't find a live download link for CME 12.0 ((. Can you help me?
09-24-2021 02:43 AM
What document ? Configuration?
if it’s compatibility matrix I have shared in my previous post.
09-24-2021 03:09 AM
Sorry, I mean the archive with the installation files. I can't find it on cisco.com
09-24-2021 07:18 PM
I hope you are looking for the below two links. For 12.0 upgrade your IOS router to Release 15.7.3M8. 15.7(3)M4 is a deferred version.
https://software.cisco.com/download/home/282774229/type/280805680/release/15.7.3M8?i=!pp
https://software.cisco.com/download/home/286322832/type/282786567/release/12.0
