upgrade ESXi 5.5 to 6.5
aneesh.abraham
Hi Team,
         we have CUCM 11.5 installed on BE6M server, the current ESXi version is 5.5, we are planning to upgrade ESXi to 6.5,  when i check virtualization wiki for the compatibility it shows that 6.5 is supported (Supported Versions of VMware vSphere ESXi= 5.0 U1, 5.1, 5.5, 6.0, 6.5 (6.5 - VMFS 5 or 6, minimum OVA file version cucm_11.5_vmv8_v1.1.ova required, fresh install only); HX TRC 6.0 only)
       Here I have a confusion , whether it says ESXi 6.5 only supports a fresh installation. Our CUCM initially installed as 10.5 and then upgraded to 11.5.
Please advise is it safe to upgrade the ESXi to 6.5 on this environment.
Aneesh
As per cisco standard CUCM 11.5 will support 5.0 U1, 5.1, 5.5, 6.0, 6.5 .
If fresh Installation  for   ESXi 6.5 - VMFS 5 or 6, minimum OVA file version cucm_11.5_vmv8_v1.1.ova required . But in your current  setup version is ESXi  5.5.
You can upgrade to 6.5 . Post upgrade verify the  cucm_11.5_vmv8_v1.1.ova template recommendation . If did not match your current Hardware resources for ESXi  change to cisco recommendation values  .
CUCM 150 user node (BE6K only): Cisco Unified Communications Manager (CUCM) configuration that supports up to 150 users per node (BE6K only). Details: Red Hat Enterprise Linux 6 (64-bit) CPU: 2 vCPU with 800 MHz reservation Memory: 4 GB with 4 GB reservation Disk: 1 - 80 GB disk with pre-aligned disk partitions
https://www.cisco.com/web/software/283088407/133457/CUCM_11.5_VirtualServerTemplate8_v1.1_Readme.pdf
based on your Deployment type choose vCPU, RAM ,HDD etc..
ESXi license part I’m not sure form 5.5 to 6.5 . Please check with VMware  team .
Thanks & Regards,
S. Ramamoorthy
Ram.S
6 Replies 6
Thanks & Regards,
S. Ramamoorthy
Ram.S
Hello Ramam,
Could you pls share the steps for upgrade ESXI 5.5 to 6.5 followed by you..
I have UCS 220 M4 and CUCM 10.5
@anilkumar.cisco
Check this out.
https://www.youtube.com/watch?v=cXCbt3UO0os
Its very helpfull. I performed the test in my lab and was successfull.
*** Please rate helpful post. Please mark as answer if it solves your problem/query.
regards, Ritesh Desai
Alternative Method How to configure VMware Update Manger & Upgrade ESXi Host in vCenter Appliance 6.7 - Full Demo https://www.youtube.com/watch?v=TODFu5f5WsY You can run the ESXi 6.0 installer from a CD/DVD or USB flash drive to do an interactive upgrade or migration. This method is appropriate ...
thanks..
Do I need to take care about some update patchs on CUCM..
currently my CUCM is 10.5(2)SU2a version..
jkilleda
Level 3
Level 3
Hello Aneesh,
Upgrade ESXi 5.5 to 6.5
Supported version of VMWare VSphere ESXI for CUCM 11.5 : 5.0 U1, 5.1, 5.5, and 6.0
