Upgrade Unity 7.x from 4.x
cvicentep
Hi everybody, i like to upgrade unity 7.x from 4.x... but i don't know if first upgrade to 5.x or not.
Jaime Valencia
no, there is no need
you can refer to the install guides
Install and Upgrade Information for Cisco Unity Release 7.x
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/7x/redirect/7xinstallupgradeinfo.html
java
if this helps, please rate
java
Rob Huffman
Hi Carlos,
Just to add a note to the great tips from my friend Java.+5 points Java!
Upgrading Cisco Unity 4.x Software to the Shipping Version
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/42/upgrade/guide/ex/ru_010.html#wp1334870
For upgrades from Cisco Unity 4.x to version 7.0(2), see the "Upgrading Cisco Unity 4.x Software to the Shipping 5.x Version" chapter of the Reconfiguration and Upgrade Guide for Cisco Unity. See also the "Installation and Upgrade Notes" section.
Note The following links go to Release 5.x versions of the guide; all 5.x content applies to version 7.x as well.
•Reconfiguration and Upgrade Guide for Cisco Unity Release 5.x (With IBM Lotus Domino) at http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/upgrade/guide/dom/5xcurugdx.html.
•Reconfiguration and Upgrade Guide for Cisco Unity Release 5.x (With Microsoft Exchange) at http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/upgrade/guide/ex/5xcurugex.html.
Caution Upgrading from Cisco Unity 3.x directly to Cisco Unity 7.0(2) is not supported. You must upgrade to Cisco Unity 4.x first, then upgrade again from 4.x to 7.x.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/7x/release/notes/702curelnotes.html#wp47469
Hope this helps!
Rob
