I keep getting this when I do 'sh isdn status' on my AS5300. The only thing that fixes it that I've found is a reload of the entire system. What are some debugs that I can run to see what's going on?
Hello,I have CCM 7,and 7985 endpoint registered as SCCP endpoint.Our Need, to communicate with Tandberg endpoint that can be accessed via IP.Is there any requirement to use Gatekeeper and register both endpoints to it ?Regards
Hi. I bought some CP7911G-Ch1, and two of them presents the following issue: When I connect the phone , inmediately the lights of the MWI, the hold button and the Applications menu turns on, and nothing it's display on the screen. The phone doesn't...
Hi,It's possible to override ISDN type and plan for inbound calls from Telco?Best regards.
Is it possible to do the downgrade from 2.3.4 to 2.2.2 for CUE , becasue I need ver 2.2.2 to communicate with Call mansger ver4.0 , any reply will be vrey appreciated.
Please let me knew whether MCS-7845-I1-CCI/ECS2 support ip version 6 or not ?If so please send me the link for config.Sami
Is there a way to manipulate the CLID of inbound calls such to place a 9 and 1 in front of number?The reason for this is so that phone users could just select the DIAL button from the directory without having to EditDial first?Thanx, Seth
Can we see the phone status if the user is on the phone or not? before we reset the phone.Since we will disconnect the phone if we reset the phone.We have CUCM 6.11.Thanks
-CUCM7.0.1-Caller(cell)number=4162223333-remote destination number=4162223333-desk phone extension=4694-call flow1) dial to MVA DID number w/ani=41622233332) gateway deliver the call to CUCM via SIP trunk3) CUCM sends back the call to gateway via h32...
hi all,i'm working with cucm 6.1, and i want to configure local directory in the phones, so i'll be able to call from the directory of the phones, i ask your help (document, idea etc...)any idea will be appreciatedbest regardsMed
Hi everybody, i like to upgrade unity 7.x from 4.x... but i don't know if first upgrade to 5.x or not.Thanks
Tengo una pregunta para ver si me puedes ayudar, digamos que hay una oficina principal y una sede pequeña en la misma ciudad...y un solo callmanager en la oficina principal.La oficina principal tiene un e1 y la sede tiene una linea fxo. Resulta q lo...
Is there a way to program a waiting room set that as soon as it is picked up it will dial the receptionist or security. The set will not be able to dial anything else. I don't know the term to use for this type of feature.
How can I slow the DTMF signals coming out of a vic2-2fxo. Call manager 4.1, cisco 2801 router, Just switched from AT&T pots (no centrex, no 9) to Time Warner Digital Cable, and it won't dial out.. incoming is fine. No other changes have been made....
Hi All,I have upgraded the CUCM server from 6.1.1.2000-3 to 6.1.3.1000-16. After finishing the upgrade, I am getting the below message on the main web page of the CUCMCisco Unified CM AdministrationSystem version: 6.1.3.1000-16Licensing Warnings: ...
Subject | Author | Posted |
04-28-2025 11:36 AM | ||
04-28-2025 05:35 AM | ||
04-26-2025 05:48 AM | ||
04-24-2025 02:49 PM | ||
04-15-2025 02:12 PM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
